S2 RST Calipers
Old Apr 2, 2007 | 05:57 PM
matthart's Avatar
matthart
Default S2 RST Calipers
Im running S2 brakes on my Orion and recently had the passenger side caliper blow a seal.
I bought a replacement from my local factors, but when I got it home its got a slight difference. All the bolt holes and piston is the same, its just this end:
Is that a true S2 caliper??
Thanks!
Old Apr 2, 2007 | 07:20 PM
NO, not as ford fitted anyway, different as it is a pattern part, stil ok though and might be better as it would have any design upgrades built into it, if problems were found with oe ones.
Old Apr 3, 2007 | 01:24 AM
SafeChav's Avatar
SafeChav
Only asthetically different, its the same in terms on functionality although could be annoying come time to change the pads if you use a service kit, as the spring clips differ as you are aware!
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
