Slight oil leak
Old Apr 2, 2007 | 10:20 AM
Davie's Avatar
Davie
Default Slight oil leak
When removing my starter at the weekend, i noticed a little drip of oil on the bottom of the actuator?
Where could this be coming from? Car is due at AVA in 2 weeks, is this a major problem?
Old Apr 2, 2007 | 10:39 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Could be a couple of places:
Oil feed to turbo
Oil return from turbo (turbo end - either gasket for the metal return pipe or the join where the oil return rubber hose joins the metal return pipe)
Oil return rubber hose where it joins the block - also check for splits in the hose.
Rocker cover Gasket.
Depending on where its coming from and how much its dripping it may or may not be a problem, best to investigate/keep an eye on the oil level just in case tho!
Old Apr 2, 2007 | 10:44 AM
Marc LJX's Avatar
Marc LJX
Could be a leaky actuator oil seal, (The oil mist in the air is collecting inside the actuator, and leaking out).
Clean everything up and keep an eye on it...
IainRS1700T
Sep 25, 2015 06:44 AM
krypton
Sep 23, 2015 07:29 PM
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
The Enigma
Sep 12, 2015 10:12 PM
