engine stand
Old Apr 1, 2007 | 06:14 PM
Chris69's Avatar
Chris69
Default engine stand
just bought myself an engine stand from machinemart, best place i can see to attach my cvh block to it is the four holes on the flywheel end.
Will this be ok??, any advice on wot bolts or any other ways to mount it etc so i can start strpping and replacing bits on the engine.
Old Apr 1, 2007 | 06:36 PM
escrst's Avatar
escrst
yeah use the mounting lugs poking out each side for the gear box an the two that are on the top of the block where the two top gearbox bolts go.
Old Apr 1, 2007 | 06:38 PM
smitsturbo's Avatar
smitsturbo
i have seen them bolt up to the front/back of the engne but never realy looked how
Old Apr 2, 2007 | 08:10 AM
twinkle_2k86's Avatar
twinkle_2k86
heres how to bolt it on mate.You can just about see the bolts where they go through the gearbox mounting holes.
You can just use any bolts realy to hold it on, not special needed at all.
Old Apr 2, 2007 | 01:00 PM
Chris69's Avatar
Chris69
great stuff jon mate
got me some nice strong 10mm bolts from wrk so i'm off to do that, cheers
Old Apr 2, 2007 | 04:43 PM
Moonie's Avatar
Moonie
IIRC the head bolts are the same thread as the gearbox mounting bolts.
Old Apr 3, 2007 | 12:24 AM
SafeChav's Avatar
SafeChav
Default Re: engine stand
congratulations
Is that capable of holding beiges?
Billy_RS
16
Oct 11, 2025 09:41 PM
Sheepdisease
Aug 30, 2015 09:11 PM
TrevCos
Aug 22, 2015 06:05 PM
IAN RS2k
Aug 18, 2015 07:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
