aquamist
Old Apr 1, 2007 | 05:33 PM
lewis_lisa's Avatar
lewis_lisa
Default aquamist
can some1 tell me how my aquamist works and how do i make sure its working prop do i need to fill anywhere with water to make the mist
i dont have a clue about this and would be happy with any help guys
Old Apr 1, 2007 | 06:36 PM
smitsturbo's Avatar
smitsturbo
my thinking is you have a tank somewhere in the car wich feeds a wee pump wich squerts mist just before the inlet like nos but cools the charge temps, am i right?
Old Apr 1, 2007 | 07:21 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Yep you should have a bag or reservoir somewhere mate that you fill with water.
Old Apr 1, 2007 | 07:54 PM
lewis_lisa's Avatar
lewis_lisa
o.k i think i understand what it does now im not sure where this little tank is though as ive never filled it up before
Old Apr 1, 2007 | 08:10 PM
T28 RST's Avatar
T28 RST
Ok then
Lewis where does your water injection connect to your engine
Old Apr 1, 2007 | 08:45 PM
lewis_lisa's Avatar
lewis_lisa
davie in the 2nd pic its the metalic blue thing behind the end of metering head with a small black hose coming out of it hope this helps m8 if this was not working properly i.e no water in it would it cause the engine to run ruff
Old Apr 1, 2007 | 08:51 PM
T28 RST's Avatar
T28 RST
Ok then
You talking about these bits
Old Apr 1, 2007 | 09:08 PM
lewis_lisa's Avatar
lewis_lisa
thats it there m8
Free image hosting by http://www.holdthatpic.com/
Old Apr 1, 2007 | 09:17 PM
T28 RST's Avatar
T28 RST
Ok then
Originally Posted by lewis_lisa
thats it there m8
Might be wrong but that doesnt look like water injection
What else connects to that wee block
Old Apr 1, 2007 | 09:29 PM
lewis_lisa's Avatar
lewis_lisa
it goes to brake servo m8 the only reason im saying thats it is cause it says aquamist on it m8. i'd prob be best just showing you the car m8
there is an injector driver on top of the fuse box but i think that might be for the 5th sorry m8 im not 100% on the car yet still learning bits
Jasesapphy
Aug 29, 2010 01:31 PM
Jasesapphy
Jun 13, 2010 08:05 PM
RobS
37
Mar 13, 2007 08:18 AM
