GRS coolers
Old Mar 31, 2007 | 06:57 AM
T28 RST's Avatar
T28 RST
Ok then
Default GRS coolers
Need some advice for a freind
need some advice on how much of the front panel needs cut away for the coolant fan with GRS intercooler???? won't get my intercooler for approx 5 weeks and my car will prob be painted by then. don't want to be cutting bits out ma fresh painted motor.
please help
Its going in a RS 16i
Old Apr 1, 2007 | 08:05 PM
T28 RST's Avatar
T28 RST
Ok then
Anyone
Old Apr 1, 2007 | 08:22 PM
Leggetts 4x4 Cossie's Avatar
Leggetts 4x4 Cossie
Its only a matter of a 1-2cm, thats all... if you can skim the back then you will be fine. If you have a 90Spec you will not need to cut.
Also dont forget your twin fans.
Old Apr 1, 2007 | 08:43 PM
T28 RST's Avatar
T28 RST
Ok then
Its going in an RS 1600i
Old Apr 1, 2007 | 10:19 PM
COSSIE CAL's Avatar
COSSIE CAL
need a lot of cut
Old Apr 1, 2007 | 10:35 PM
T28 RST's Avatar
T28 RST
Ok then
Originally Posted by COSSIE CAL
need a lot of cut
How much is alot
Old Apr 1, 2007 | 10:45 PM
Diamonds.'s Avatar
Diamonds.
on my S2 i never cut out anything bumper or front panel
Old Apr 1, 2007 | 10:55 PM
T28 RST's Avatar
T28 RST
Ok then
Its going on a MK3 RS 16i
Old Apr 1, 2007 | 11:50 PM
antony215's Avatar
antony215
Escort Rs Turbo
Ive seen a few with the size of the cooler cut out in the front panel
Old Apr 2, 2007 | 12:30 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Alot different to a mk3
Old Apr 2, 2007 | 12:58 AM
Diamonds.'s Avatar
Diamonds.
ah furry muff
Old Apr 3, 2007 | 08:10 PM
JesseT's Avatar
JesseT
Less needed for a single fan:
gcfcos
59
Oct 6, 2015 05:04 PM
