Efi conversion wiring. The 7 wires!
Old Mar 30, 2007 | 05:37 PM
Turbo-Beal's Avatar
Turbo-Beal
Default Efi conversion wiring. The 7 wires!
Im now well into my efi conversion and i have gutted the mfi loom, rebound the loom back up with the 7 wires ready to be terminated to my loom plug . I have some wiring diagrams but none that identify each wire by colour . Can anyone help me out? i know i could work it out but i dont want to start ripping stuff about to locate each wire correctly .
Old Mar 31, 2007 | 05:52 PM
Chris69's Avatar
Chris69
does anybody know this?
would be useful for me aswell as doing a efi conversion soon
Old Mar 31, 2007 | 07:09 PM
s1kid's Avatar
s1kid
Me also any help would be much appreciated
Old Mar 31, 2007 | 07:35 PM
smitsturbo's Avatar
smitsturbo
Turbo-Beal
post up your wiring diagrams mate
& wheres safechav
Old Mar 31, 2007 | 08:03 PM
Turbo-Beal's Avatar
Turbo-Beal
This is what iv been using so far.
And some info off here
http://www.rsbible.co.uk/
Old Apr 3, 2007 | 12:40 AM
SafeChav's Avatar
SafeChav
Don't see your problem here
If you look at the diagram the plug is drawn with all the wires in the plug in order, how can that possibly be any easier
Old Apr 3, 2007 | 07:36 PM
Turbo-Beal's Avatar
Turbo-Beal
well i want to be shure that i connect each wire up correctly i.e which colour to which pin. I actually have 8 wires
1. brown/green
2. green/red
3. green
4. black/red
5. black/green
6/7. black x2
8. 1 larger black wire
As stated i could figure it out but if someone already knows it could save me some working out.
Old Apr 4, 2007 | 06:36 AM
turboash's Avatar
turboash
Default efi
silly question maybe but which relay is which in that diagram ie red or yellow and are both the relays the same physical size
Old Apr 4, 2007 | 05:02 PM
SafeChav's Avatar
SafeChav
1. brown/green
2. green/red
3. green
4. black/red
5. black/green
6/7. black x2
See i dont get what you mean though, the diagram shows you visually where each wire goes, i couldnt make it any simpler to explain if i tried
turboash
Fuel injection relay is red
Fuel pump relay is yellow
Old Apr 4, 2007 | 08:11 PM
Turbo-Beal's Avatar
Turbo-Beal
I wanna know what wire does what. for example the brown/green wire is the oil pressure switch. you follow? you might think im being lazy but iv bound up my loom before i had the diagram so i dont wanna unbind it to trace each wire , I wanna identify them buy coulour first. By the way i have not yet got the loom connector but i was gonna use one from a spare injector rail loom as i think its the same. Can you verify?
Old Apr 10, 2007 | 09:50 PM
turboash's Avatar
turboash
where does the oil press switch wire connect to it is my last wire to connect, someone please help
Old Apr 11, 2007 | 06:51 PM
Turbo-Beal's Avatar
Turbo-Beal
this should help Unless you mean on the loom plug itself
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
