blue colour on bolts
Old Mar 28, 2007 | 08:18 PM
efiste2's Avatar
efiste2
Default blue colour on bolts
what is the purpose of colouring/painting certain bolst blue like, these are they HIGH TENSILE or is it a threadlock of some sort, all the flywheel and clutch bolts are the same too. If its a threadlock do ford sell it
rapidcossie's Avatar
rapidcossie
stops the nuts coming off
Old Mar 28, 2007 | 08:51 PM
dave green's Avatar
dave green
Its thread lock. as said above
Dave
Old Mar 28, 2007 | 09:12 PM
efiste2's Avatar
efiste2
can u still get it......the blue coloured threadlock i mean....
Old Mar 28, 2007 | 09:49 PM
SafeChav's Avatar
SafeChav
Some of the suspension bolts are also blue, not sure if that indicates they are also high tensile or not being as even the shoulders and heads are blue
Old Mar 28, 2007 | 10:17 PM
daz1968's Avatar
daz1968
used to make these bolt were I worked, ford have different colours to identify different grades of bolts, so if someone uses a wrong bolt it is easily noticed, I think the blue was 12.9 grade but not 100% certain, I think it has this info in the cosworth workshop manual in the front.
Old Mar 29, 2007 | 06:50 PM
It is defo not thread lock at all.
It is as said a COLOUR MARKER for PRODUCTION LINES, so the wrong bolts are not installed and it makes it easier to quickly find right ones(colour).
Does not indicate tensile strength other than certain strength ones are used in certain places.
Old Mar 30, 2007 | 12:06 PM
SafeChav's Avatar
SafeChav
About the only thing i would say though, is on a Ford there are only a handful of bolts which are blue, the rest are just galvanized.
The blue ones i can think of, off the top of my head:
Front inner TCA bolts, rear gearbox mount bolts, front engine mount bolts, rear drum backplate to hub bolts, there may be a couple of others but thats about it
Old Apr 1, 2007 | 10:48 AM
BLUE is ISO METRIC 10.9 grade
RED is ISO METRIC 12.9 GRADE
Old Apr 1, 2007 | 03:09 PM
dave green's Avatar
dave green
Thought you ment the blue that you see on caliper bolts, you get new ones in the box when you replace brake pads.
Dave
Old Apr 2, 2007 | 10:02 PM
SafeChav's Avatar
SafeChav
Any examples of which ones are red at all for reference?
Nov 1, 2015 06:53 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
