Fitting a L.S.D. in a ib5 gearbox
Old Mar 28, 2007 | 11:33 AM
twinkle_2k86's Avatar
twinkle_2k86
Default Fitting a L.S.D. in a ib5 gearbox
How bad is it to fit a standard RS turbo L.S.D. into a ib5 gearbox?
does the gearbox have to be taken completely apart to fit it? is it a job that could be done at home, or do you need special tools.
Im conferdent enough to strip the gearbox, just not sure is specail tools are required, and if the box does need to be stripped completely.
also i know this was talked about not long ago. but if i find a gearbox from a mk6 escort, front mounted starter, will my gearbox mounts line up? or does it require some other mods.
its all going in a S2 RS turbo.
cheers
Old Mar 28, 2007 | 03:56 PM
SafeChav's Avatar
SafeChav
You have to split the casing obviously to get into the differential, but a S2 LSD drops straight in from what ive been told.
As i said to you, you'll more than likely need a puller for 5th gear.
The box should drop straight into the car
Old Mar 28, 2007 | 04:50 PM
BillyCabrio's Avatar
BillyCabrio
Would that be the same for a Quaife in an iB5?
Old Mar 28, 2007 | 04:55 PM
SafeChav's Avatar
SafeChav
Stop asking more complicated questions
BillyCabrio
Old Mar 28, 2007 | 04:58 PM
SafeChav's Avatar
SafeChav
The quaife is probably worth more than your car anyway
Old Mar 28, 2007 | 05:29 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Yes...
Old Mar 28, 2007 | 05:54 PM
BillyCabrio
SafeChav
Yeah says you
Tony Turbo
Cheers Tone
Old Mar 28, 2007 | 06:09 PM
SafeChav's Avatar
SafeChav
SafeChav
Yeah says you
Says me
my car cost £230 its been written off by most of the parts i fitted to it
Old Mar 28, 2007 | 06:25 PM
Mixja's Avatar
Mixja
420
SafeChav
Yeah says you
Says me
are u selling it for £230 then...??
Old Mar 28, 2007 | 06:27 PM
SafeChav's Avatar
SafeChav
SafeChav
Yeah says you
Says me
are u selling it for £2300 then...??
I'd probably take that yea
Old Mar 28, 2007 | 06:36 PM
Mixja's Avatar
Mixja
420
Default Re: Fitting a L.S.D. in a ib5 gearbox
oo, ill have 2...!!
id like to know this as well....
Old Mar 28, 2007 | 06:38 PM
SafeChav's Avatar
SafeChav
oo, ill have 2...!!
I've already said it will drop straight in
blind or stupid? Which are you
Old Mar 28, 2007 | 06:50 PM
Mixja's Avatar
Mixja
420
dunno, both i guess...
Old Mar 28, 2007 | 06:53 PM
SafeChav's Avatar
SafeChav
Owwwwwww bad luck old chap
Old Mar 28, 2007 | 08:10 PM
Mixja's Avatar
Mixja
420
s'ok, u learn to live with it...
Chas
Sep 21, 2015 08:57 PM
druidgetafix
Aug 15, 2015 10:22 AM
RsS2daz
Aug 14, 2015 05:26 AM
RIB1122
Aug 13, 2015 09:09 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
