Rear Standard Suspension
Old Mar 26, 2007 | 12:45 AM
Diamonds.'s Avatar
Diamonds.
Default Rear Standard Suspension
is a MK4 XR3i Cabrio Standard Rear Suspension the same as S2's Standard Rear Suspension?
just a question ive been asked as im breaking a cabby and i want to be 110%
cheeRS peeps
Rob
Old Mar 26, 2007 | 03:41 AM
Alex_86's Avatar
Alex_86
it´s the same
all mk4
Old Mar 26, 2007 | 03:43 AM
Diamonds.'s Avatar
Diamonds.
thank you
Old Mar 26, 2007 | 02:09 PM
Micky's Avatar
Micky
It may not be the same as I doubt the cabby has a anti roll bar????Regards,Micky
Old Mar 26, 2007 | 02:21 PM
ivorbiggun's Avatar
ivorbiggun
It doesn't
Old Mar 26, 2007 | 02:29 PM
SafeChav's Avatar
SafeChav
I was under the impression RS springs are slightly lower
MK4 cabby's dont have rear ARB's im sure, a S2 does!
Old Mar 26, 2007 | 02:55 PM
Diamonds.'s Avatar
Diamonds.
ooh bugger
Old Mar 26, 2007 | 03:00 PM
SafeChav's Avatar
SafeChav
Why whats up?
And are u breaking a Mk3 or Mk4
Old Mar 26, 2007 | 03:08 PM
Diamonds.'s Avatar
Diamonds.
mk4 dude just a fella asked on here but i dont want to sell him bits that dont fit his turbo.
Old Mar 26, 2007 | 04:16 PM
addiction's Avatar
addiction
springs will be different height
Old Mar 26, 2007 | 04:21 PM
Diamonds.'s Avatar
Diamonds.
thanks guys that clears that up for me
Old Mar 26, 2007 | 05:05 PM
SafeChav's Avatar
SafeChav
Fancy donating me a passenger door
Old Mar 26, 2007 | 05:10 PM
Alex_86's Avatar
Alex_86
The dampers and the springs are the same!
The springs will be in the same size/hight
I know, I have one
And as i could understand the question was not about rear anti roll bar
the cabby is stiff any way, because the lack of hard roof
it is stiffen up behind with the blue metal plate that is right behind the rear back seats
suspensions was going to this car:
ended up on this one:
the S2 and the xr3i is lower than the other mk4´s.
don´t remember how much lower
and the dampers and springs are all the same on MK4
one example is:
Burtonpower is selling a koni kit
Part No: KOSSK1
Description: KONI KIT MK3/4 ESCORT '83-90
Other Info: BASE MODELS -40mm/XR3i/TURBO -20mm
Old Mar 26, 2007 | 05:19 PM
SafeChav's Avatar
SafeChav
An ARB is part of suspension!
And as i and Addiction have said, im sure by the spec an S2 is lower than a 3i
Old Mar 26, 2007 | 05:24 PM
Alex_86's Avatar
Alex_86
nope, xr3i and the S2 is the same hight
and when you change suspension you change the arb?
Old Mar 26, 2007 | 05:27 PM
smitsturbo's Avatar
smitsturbo
im pretty sure the s2 is lower than xr3i's i think 20mm
Old Mar 26, 2007 | 05:30 PM
Alex_86's Avatar
Alex_86
haha, talking to u English men is difficult
SafeChav's Avatar
SafeChav
The cabby suspension arms wont have the ARB mounts for one.
Just admit you're wrong be a whole lot easier
Old Mar 26, 2007 | 05:36 PM
Alex_86's Avatar
Alex_86
the cabby suspension arms wont have the ARB mounts for one.
u change them to when u change dampers and springs?
I haven't said that the cabby have rear ARB I know it does not have on, I have a cabby, remember
Old Mar 26, 2007 | 06:07 PM
SafeChav's Avatar
SafeChav
how can you change them? The mounts are welded onto the wishbones!
And an ANTI ROLL BAR is part of the rear suspension, S2's have them, cabby's don't, you are wrong
end of story
thankyou please
Old Mar 26, 2007 | 06:25 PM
Alex_86's Avatar
Alex_86
what are you talking about?
I am talking about dampers and springs
They are not welded on!!!
They are the same
mister:
end of story
thank you please
Old Mar 26, 2007 | 06:29 PM
SafeChav's Avatar
SafeChav
dampers and springs are part of suspension, as are wishbones ARB's tie bars and so on.
Diamonds, what were you going to sell to the chap?
Old Mar 26, 2007 | 06:32 PM
Diamonds.'s Avatar
Diamonds.
all he asked for was the rear suspension. As far as i know it was to make a rolling shell
Old Mar 26, 2007 | 06:45 PM
Micky's Avatar
Micky
Since when is the shocks and springs the only parts of suspension???Diamonds asked about suspension in his origional question,not shocks/springs!!!!Micky
Old Mar 26, 2007 | 06:56 PM
Alex_86's Avatar
Alex_86
Dont think you have much of a clue mate to be honest.Firstly the above example you've shown is for a KONI shock and spring kit.Whats that got to do with standard FORD shocks and more importantly spring height????Secondly,since when is the shocks and springs the only parts of suspension???Diamonds asked about suspension in his origional question,not shocks/springs!!!!Micky
Dont think you have much of a clue your self mate!
Its a koni kit, as an example. there the springs: if you put in on the basic models it will lower it 40mm, if you put it on a xr3i and a S2 it lower it 20mm.. and whys does it lowers the xr3i and S2 the same?
Could it possible be because its the same hight?
So if you read it all and think a little you could see that the post have
got a little OT to the hight between xr3i and S2
so read then post!!!! Alex
and about the suspension , did think it was about the dampers and springs and not about the hole system
tulling
Old Mar 26, 2007 | 07:03 PM
SafeChav's Avatar
SafeChav
ooooo what a bitchy thread this is turning into
Diamonds as far as it goes, im 99.9% sure the S2 springs sit the car lower compared to 3i springs.
The rear wishbones won't have the rear ARB mounts, and obvio the car doesn't have the ARB either.
Shocks im pretty sure are the same.
Alex_86, you'll find manufacturers around that make spring kits and list the differences in heigh it makes between a S2 and a 3i
Old Mar 26, 2007 | 07:07 PM
Alex_86's Avatar
Alex_86
hehe lol
SafeChav: I know you could find it in diffrent hights to the xr3i and the S2 the cabby dont have the ARb at all thats right
if I got some time, i will stop at Ford after work tomorrow and ask
Old Mar 26, 2007 | 07:16 PM
SafeChav's Avatar
SafeChav
hehe lol
No what i mean, is a set of lowering springs, you fit them to a 3i, and it will make the car a lower overall drop than if fitted to an S2. Its the ride height figure thats relevant.
We need some original Ford sales brochures to look at the official ride height figures.
And you think the muppets at ford are going to know that! Wishful thinking if ever i heard it
Diamonds.'s Avatar
Diamonds.
sorry peeps didnt mean to turn this into fight
Old Mar 26, 2007 | 07:19 PM
SafeChav's Avatar
SafeChav
Damn striaght
This ain't the muppet room you know
Old Mar 26, 2007 | 07:45 PM
Alex_86's Avatar
Alex_86
hehe, they know allot at ford here, so i gone ask anyway, afraid of the answer
dont fight, just talking
sorry if any one think i was rood to them
Old Mar 26, 2007 | 07:52 PM
Diamonds.'s Avatar
Diamonds.
Old Mar 26, 2007 | 10:54 PM
addiction's Avatar
addiction
I done some research and it turns out that Alex is right on the xr3i and s2 being the same height. the mk3's were different though.
the mk4 xr3i and Rs turbo had the same ride height of 1349mm compared to the other models at 1369 mm.
the mk3 xr3i was 1380mm and the Rs turbo was 1349 mm and all other models 1380mm
Old Mar 26, 2007 | 10:58 PM
SafeChav's Avatar
SafeChav
WANKER
Well im a Mk3 man so that is my defence, however poor it may be
Old Mar 26, 2007 | 11:10 PM
Diamonds.'s Avatar
Diamonds.
Old Mar 26, 2007 | 11:16 PM
SafeChav's Avatar
SafeChav
Diamonds, so as i was saying, you can sell him the shocks and springs
Old Mar 27, 2007 | 12:10 AM
Diamonds.'s Avatar
Diamonds.
he's gone somewhere else now
Old Mar 27, 2007 | 12:12 AM
SafeChav's Avatar
SafeChav
FUCK
You didn't say whether you fancied donating a door to me either
Old Mar 27, 2007 | 12:26 AM
Diamonds.'s Avatar
Diamonds.
ill pm ya a pic of it 2morro for you if you want dude? it does have a dent in it though golf ball size
Old Mar 27, 2007 | 03:24 AM
Alex_86's Avatar
Alex_86
