What major things could/should be changed before 50K?
Old Sep 13, 2004 | 08:56 PM
M7 COS's Avatar
M7 COS
Default What major things could/should be changed before 50K?
Head Gasket?
Turbo?
ETC.
Anything else?
Thanks
Old Sep 14, 2004 | 12:35 AM
bbigman2000's Avatar
bbigman2000
Timing belt mate, belt tensioners, you wanna change the diff and gearbox oils regulary
those other items you mention have a good long service life as long as you run the car carefully,. give it fresh oils all the time and warm up and cool down properly, the quickest way to feck yer turbo is by shutting it down before its moving parts have had chance to cool.
its spinning at 100,000 rpm or something daft so it needs looking after and will last ages
Old Sep 14, 2004 | 12:35 PM
Dave Henshall's Avatar
Dave Henshall
dont do the headgasket unless it needs doing though. if its not broke, dont fix it - UNLESS , you ar eloking at upping the power and want it doing right in the 1st place.
Old Sep 14, 2004 | 06:48 PM
M7 COS's Avatar
M7 COS
Thanks for the advice guys.
No big power plans, just sweet and standard, when I actually get one!!!
Will probably have it set up at EA though as they're just down the road from me.
rex647
Mar 6, 2022 06:20 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
