RS2K brake
Old Mar 24, 2007 | 09:24 AM
jaminescort1985's Avatar
jaminescort1985
Default RS2K brake
hey guys and gals i'm new to the modin sence and need a little advice, can anyone tell me if it is a straight swap to fit mk5 RS2K disc's, pads and callipers on a standard mk6? Also if you can fit mk5 RS2K callipers round mk6 RS2K disc's?
many thanks
Old Mar 24, 2007 | 01:04 PM
FORD tend to use the same hub dimensions on their cars so should go straight on if you use the correct carrier that was with the calipers.
Old Mar 24, 2007 | 03:23 PM
jaminescort1985
ok thanks a lot thats a big help
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
