clutch release arm help
Old Mar 22, 2007 | 05:04 PM
efiste2's Avatar
efiste2
Default clutch release arm help
this is off my mk4 escort XR3i, does anyone know if this is correct, the part below is a clutch release arm and as you can see one leg has a roll pin in one end to loacate the release bearing but not the other leg, IS THIS HOW IT IS SUPPOSED TO BE ??? by the way i didnt take it apart so i dont know how it came off
Old Mar 22, 2007 | 05:11 PM
antony215's Avatar
antony215
Escort Rs Turbo
Yes
Old Mar 22, 2007 | 05:19 PM
efiste2's Avatar
efiste2
So theres only the one pin that holds the release bearing on, and the other just rests against it thanks for the help mate
Old Mar 22, 2007 | 05:24 PM
antony215's Avatar
antony215
Escort Rs Turbo
Yep i done mine about 2 months ago because the top pin had snaped off and jamed the release bearing so i couldn't get any gears
Old Mar 22, 2007 | 06:49 PM
efiste2's Avatar
efiste2
thanks for all your help, its appreciated!!!
Old Mar 22, 2007 | 06:51 PM
efiste2's Avatar
efiste2
by the way mate, dont suppose you rememeber what bushes went where did you, ie is there a bush at the bottom of the release arm, i know theres one at the top where the arm meets the cable arm, but what is at the bottom end of the release arm
Old Mar 22, 2007 | 07:20 PM
Moonie's Avatar
Moonie
Old Mar 22, 2007 | 07:24 PM
efiste2's Avatar
efiste2
thats a more modern micro cat than mine mate, and that answers evrything bar one thing, can you give me the part number of 10 A
Old Mar 22, 2007 | 09:30 PM
SafeChav's Avatar
SafeChav
That clutch fork is completely normal, it only has one pin otherwise you wouldn't be able to hook the bearing over, once the box is in situ it is constantly in contact with the diaphram springs.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
