bad luck (again)
Old Mar 21, 2007 | 08:39 PM
righthooker's Avatar
righthooker
Default bad luck (again)
Just cant shake the curse
After the cossie H/G,transit clutch ,sons car getting done (mothersday) Last night i put the Frontera into 4wd and the tranfer went BANG
Then tonight i go over to get the cluch fitted in the tranny as a mate has access to a pit where he works ,and after removing the old clutch and fly wheel it becomes evident that FORD PARTS department have given me the wrong parts I even gave em the regestration number of the transit.
All i need now is to find that the cossie has a cracked block and not a H/G problem ,that would be the iceing on the cake (real tears)
Old Mar 21, 2007 | 08:44 PM
Mr RS500's Avatar
Mr RS500
Bloody hell clive ,,,,,,,Dont bother buying a lotto ticket as it will be a winner but you will only loose it
Good luck is round the corner mate
Old Mar 21, 2007 | 08:52 PM
plynchy's Avatar
plynchy
Fookin hell!
Stay away from me at Donny mate, if you get there.
Shit luck mate, chin up.
Old Mar 21, 2007 | 08:59 PM
righthooker
Originally Posted by plynchy
Fookin hell!
If this bad luck keeps going till Donny mate i wont be there proberbly wrap the 3 door or blow it up
Old Mar 21, 2007 | 09:03 PM
plynchy's Avatar
plynchy
Months away yet dude, i'm sure you'll be sorted by then, you just need to build a new hadrians wall to cover the cost of it all (and the wedding).
While i'm on, can you PM me your home email, need to send you copies of the Donny paperwork.
Old Mar 21, 2007 | 09:15 PM
Dicko&Vacant's Avatar
Dicko&Vacant
it could be worse clive, you could be skint too!!!!!!!
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fordmad!
Sep 29, 2015 07:03 PM
Fiddy
21
Sep 29, 2015 06:10 PM
