Escort Cosworth Long studded block
Old Mar 21, 2007 | 07:41 PM
rstoughy's Avatar
rstoughy
Default Escort Cosworth Long studded block
Just a quickie for anyone in the know.
If a block is long studded (centre 6) do you have to replace the studs if you remove the Cyl head or are they fine to be re used?
Old Mar 21, 2007 | 07:47 PM
The DIVA's Avatar
The DIVA
Re-usable Paul,just change the outer four....
Old Mar 21, 2007 | 07:49 PM
rstoughy's Avatar
rstoughy
Nice one Rob
Thanks Mate
Old Mar 22, 2007 | 05:44 PM
Mark_1's Avatar
Mark_1
usually the outer four is regular arp studs, so you dont have to swap them either.
Old Mar 22, 2007 | 05:53 PM
The DIVA's Avatar
The DIVA
Good point...
Forgot to ask if it had std cossie stretch bolts or ARP studs and nuts..
Old Mar 22, 2007 | 06:05 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
i've got 6 long and 4 used standard bolts........all is well
Old Mar 22, 2007 | 10:46 PM
rstoughy's Avatar
rstoughy
Looks like standard stretch bolts in the 4 corners (splined heads) but need to get a socked machined down tomorrow to fit through the head to get to the nuts so havent really looked at it tonight.
Old Mar 22, 2007 | 10:52 PM
The DIVA's Avatar
The DIVA
If they are std bolts Paul,chuck em in the bin and replace them.....
Old Mar 22, 2007 | 11:02 PM
rstoughy's Avatar
rstoughy
Always would Rob
Want this thing to be as reliable as it can be so no short cuts
Cheers,
Old Mar 23, 2007 | 06:45 AM
pete mcrash
cos u all know better than a major tuner who does this shit everyday....... standard 4 is well up to it........t38 32psi spike......28/29 held.......ta
Old Mar 23, 2007 | 07:40 AM
GUZZLER's Avatar
GUZZLER
i don't think they said the standard 4 wern't up to it, they said 'replace the standard 4' ie; don't re use the stretch bolts, get new stretch bolts
Old Mar 23, 2007 | 07:42 AM
The DIVA's Avatar
The DIVA
Pete,we know the std bolts are up to it,but you can only use them once.....they are not reusable as they stretch the first time you use them mate.....
I have std bolts in my Escos with 34psi spike and 28 psi held..
rstoughy's Avatar
rstoughy
Old Mar 23, 2007 | 06:00 PM
pete mcrash
ok fair e snuff...............i use 4 used standard bolts........cos they have done most of the stretching..........my pal put a new set of 4 and his gasket went straight away.....i used 4 bolts that had been used before and have no probs............the long studs are made from a much stronger/less stretchey steel.......so used standard ones seem to fit in the mix well................
Old Mar 23, 2007 | 06:25 PM
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
...the long studs are semi stretch...fine for repeated use but there must be a max number of times before you should replace lol......the outer 4 need to be new and torqued as per std.
Old Mar 23, 2007 | 06:36 PM
pete mcrash
look ^^^^^^ i'm only going from EXPERIENCE..........u can do what u get told.............when mine goes pop i'll say different.........
Old Mar 23, 2007 | 06:43 PM
Deleted by Request
Former Sponsor
...you may be mate but its still wasnt wise and you may get away with it..but for the sake of what 20 quid not worth the risk IMO...but good luck
Old Mar 23, 2007 | 06:46 PM
pete mcrash
nothing to do with cost..........i've got plenty.............look at what i've said
Old Mar 23, 2007 | 10:26 PM
Butch.'s Avatar
Butch.
It would have that if it ever see's he road
Old Mar 23, 2007 | 11:32 PM
The DIVA's Avatar
The DIVA
It`s seen the road....
I pulled it out onto the path last week....
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
