Hanging car doors - are they adjustible?
My passenger wing has rubbed on my door since i bought the car, and its increasingly pissing me off.
Is there anyway i can adjust the angle at which the door hangs, so the panel gap is correct again?
Originally Posted by JTECHSAFF
i thought the fezzy hinges were welded in place?
You need to change the door pins,
I did mine today, My bottom passenger pin had snapped
It can be a bitch of a job if there stuck in. you have to heat them up to get them out.
Cheers.
yeah, first check would need to be if there was any play in the hinge pins, open the door and grab the open end ,try to move it up and down there should be very minimal movement.
if there is movement, get a mate to see where it is while you move the door ,they are common for breaking hinges off the pillar, and pins wearing out.
either is fairly simple to sort out.
after that, you need to check the shut gap and see if thats ok, if it is you have a wing prob.
but there are ways of adjusting the gaps if you know how ,ie blocks of wood
but be carefull!
ps there are special hinge pin removing tools for these!
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
track.focus'd
Aug 12, 2015 05:53 PM
