how hard to do wasted spark driver yourself
Originally Posted by pete mcrash
thank fuck for that...........i havn't seen a post from u all day......starting to worry.........try asking Stu @ MSD.........
Think Roosie needs his own Room.
As long as your confident enough to solder the driver board wires to your ecu the only hard part is getting the two wires through the bulkhead for the ecu.
Fitted one to mine at the begining of the month took half a day at the most
Originally Posted by SECS
Daveesaunders,
I assumed he would be buying the module preinstalled into his own ecu.
This is the SAFEST way and of course its tested for you before you fit it.
Got all of the bits for mine done by MSD last week, inc ordering leads, plugs, coil pack, filters, belt, wiring etc... - sent it all off tues night, and had it back on the thursday - AWESOME service
Would recomend just sending it to them and let them work their magic if you are not 100% soldering bits to your ECU....
sridgett
Oct 1, 2015 07:30 PM
deathrider666
Sep 28, 2015 06:12 PM
SMILER258
Sep 28, 2015 09:04 AM
