blue nissan pulsar for sale(highly modified restoration)
Old Mar 20, 2007 | 03:17 PM
stew's Avatar
stew
Default blue nissan pulsar for sale(highly modified restoration)
well the time has come to try and let the japanese performance featured R go to a new home.no rush on selling it but i just do not use it anymore and am back in to sportsbikes. car is running perfectly at 398 bhp and 360 lb ft torque(a video proven 404bhp)just had a full service, 12 months mot and 6 months tax on it. for pics email pgtir@blueyonder.co.uk
£££££££££open to any offers as long as they are not daft via pm (its nowhere near what i spent on it).
will check the site everyday.full spec list plus a couple of things not listed is below
ENGINE & TRANSMISSION:-
2 litre SR20DET
Re-bored to 87mm
87 mm JE pistons with JE rings
Crank lightened, balanced, knife edged and polished
Conrods balanced and polished
All new Nissan bearings
Lightened & balanced billet OS GIKEN flywheel
HKS 264 camshafts
JUN Adjustable vernier camshaft pulleys
Full head rebuild including triple cut valve seats, new valves,
Fully ported, polished and gas flowed
Standard manifold ported, polished and Ceramic coated internal & external satin black
Cometic 1.2mm triple layer metal head gasket
ARP head stud kit
ARP conrod bolt set
GT2871R turbo
3" custom turbo inlet pipe
HKS adjustable actuator
HKS SSQV blow off valve
Custom modified engine breather set up
Samco water hose set
Samco blue vacumn tubing.
HKS EVC 4 boost controller
Mongoose exhaust system with de-cat pipe fitted and heat bandage wrapped
Stainless steel water header tank
Stainless steel power steering fluid tank
Stainless steel oil separator tank
Stainless steel oil catch breather can
Stainless steel intercooler pipe run
Stainless steel distributor cover
Stainless steel spark plug cover
Hiteq blue powder coated rocker cover
Nismo high pressure 1.3 bar radiator cap
Standard brand new dampened nissan crank pulley
Forge motor sport billet aluminium pulley set
OS GIKEN single plate clutch kit
Braided Stainless steel clutch pipe
Quaife gear kit in fully re-built gearbox
short shift kit
Gear stabilisation bush kit
Nismo solid engine mount kit
Hks oil cap
Braided Stainless steel hose on all fittings
Braided Stainless steel oil feed, water feed and water return turbo hoses
Complete throttle body assembly rebuilt
Full Nissan engine gasket kit.
Walbro 255 lph fuel pump
HKS adjustable fuel pressure regulator with aeroquip fittings
Reverse mounted rad fans
HKS S45i iridium spark plugs
Mocal front mount oil cooler system with braided hose
3 inch front mounted intercooler core
Battery relocation kit
Blitz sus air filter
All fixings used throughout car are either stainless steel or anodised blue aluminium
60 mm Apexi pillar mounted boost gauge
60 mm HKS pillar mounted oil temperature gauge
Custom made carbon fibre slam panel cover
Chassis;-
complete D2 coilover suspension kit with pillowball mounts
Custom made poly rear sub frame bushes
Whiteline anti lift kit
Whiteline sub frame align & lock kit
Fusion motor sport poly power steering rack bushes
Cusco rear upper strut brace
Cusco front lower strut brace modified to clear exhaust system
GAB front upper strut brace
All other bushes on car replaced with poly up rated versions
All sub frame, suspension and under chassis components freshly powder coated chrome
Up rated fully adjustable bump steer kit with protective rubber gaiters
GTi-R spares rear differential guard
Poly exhaust mounts throughout
Brakes;-
Wilwood 4 pot callipers with 310mm disc and rotor with EBC green stuff pads
Standard rear discs with Pagid pads
Fully re-furbished rear brake callipers
Stainless steel braided brake hoses front and rear
Brand new copper brake lines under car
AP racing silicone brake fluid DOT 5.1
Wheels:-
7 ½ “x 16 “Speedline comp 2 alloy wheels in white.
Goodyear eagle f1 tyres 205 x 45 x 16
Bodywork:-
Complete bare shell respray in metallic Poseidon blue including boot floor
Complete under side of shell stripped to bare metal and painted in blue
Complete under side of shell fully waxoyled after painting.
Pro alloy custom chrome windscreen washer bottle mounted in boot
Custom made aluminium battery box mounted in boot
All trim colour coded except rear number plate surround
Clear side repeaters all round
Front bumper modified to accept front mount cooler core
Aluminium blanking plates either side of I/C core
Laguna splitter
New standard Nissan badges on tailgate
Sr20 inside logo on tailgate
GTi-ROC.com club sticker in rear window
Interior:-
Fully re-trimmed interior including door cards in black/blue leather
All seats re-trimmed in black leather
Standard interior carpet re-dyed black
Alcantara covered dash board with custom pod housing evc boost controller unit
A-pillar moulded pod with 2 x 60mm gauges oil temp and boost
Lockwood white dial kit
Snap off steering wheel boss
Sparco flash2 steering wheel
B and M shortshift gear assembly
Pillar mounted shift light
Old Mar 20, 2007 | 04:11 PM
M.A.D.RST's Avatar
M.A.D.RST
Sounds nice, get some pics up
Old Mar 20, 2007 | 06:50 PM
stew's Avatar
stew
Old Mar 20, 2007 | 06:57 PM
Brian's Avatar
Brian
Good luck with the sale
Brian
Old Mar 20, 2007 | 07:48 PM
MancDave's Avatar
MancDave
From: Salford I used to think I was indecisive, but now I'm not too sure.
Fantastic example of the pocket rocket god i have a soft spot for these there so bloody fast god knows at 400bhp
Stew any chance of pm with a rough price to work from?
Old Mar 20, 2007 | 08:25 PM
stew's Avatar
stew
duly obliged with the pm
Old Mar 20, 2007 | 08:48 PM
RA052824's Avatar
RA052824
Damn that actully looks so nice! Best i've seen! Good luck with sale!!
Old Mar 21, 2007 | 03:15 PM
M.A.D.RST's Avatar
M.A.D.RST
Old Mar 21, 2007 | 06:17 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
hiya mate, same for me to if ya dont mind ie a rough price plz mate. beautiful example.
dave.
Old Mar 21, 2007 | 06:28 PM
MattyRST's Avatar
MattyRST
That looks as fcuk
Old Mar 22, 2007 | 07:05 PM
mellor's Avatar
mellor
jeeesus thats nice, nicest and tidyest one ive seen in a long while!
my mates just finished his and is in the process of putting it back together, it made just over 500bhp on the dyno, with it all stripped out and new gearbox it sould be mental - shame it looks like a shedded sunny (de-pulsar'd it)
again - lovely car mate, shame my insurance would just laugh
Old Mar 22, 2007 | 07:36 PM
EssexMikeSi's Avatar
EssexMikeSi
bloody hell, now theres a spec sheet and a half. I dont normally like these, mainly coz most u see are black and look a bit rough, but this ones gorgeous example. Best of luck with the sale
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
