Efi managment
OFAC Fiesta turbo ECU. (OFAB can be used but takes a little bit more work)
Ecu related MAP sensor. (OFAC ecu will need an OFAC MAP sensor)
Fiesta turbo engine, or mixture of adapter plates and a trigger for the CPS.
EFi inlet manifold, throttle body and charge carrier
ACT sensor, from the fiesta turbo
Throttle body to charge carrier pipe, still available from Ford at the moment!
EFi flywheel, Fiesta RS, XR2i, XR3i (EFi)
XR3i EFi whole loom
XR3i Throttle cable and pedal
EDIS Module and coil pack etc from XR3i (or Fiesta RS)
XR3i EFi whole loom
Well it'll probably work in practice, but Ford fitted a different one to the FRSt for a reason!
Obviously there is going to be a lot higher temperatures seen in a forced induction motor at certain times
was looking at these yesterday,maybe one of these would work
if only i could understand thread sizes
http://www.bsr-aerotek.com/store/ind...Path=2_199_201
http://www.oddkiddcreations.co.uk/forum/
Everything you need to know about cossie management conversion on there.
Originally Posted by SafeChav
The easiest thing to do if possible would be to find a rotten XR2i or XR3i, then you only need a turbo ECU and MAP sensor
2i and 3i with EFI will it have to be a CVH one yeh?
Originally Posted by R6Franky
Dan
Dan
Dan
Dan
Quagmire yeah, so it'd need to be a 8v 2i.
Orion EFI also is the same thing, well pointed out (i shouldn't forget that being an Orion nut
R6Franky, as good as mate, saves you changing the whole loom, not as asthetically pleasing though
)R6Franky, as good as mate, saves you changing the whole loom, not as asthetically pleasing though
mk3ste
Oct 17, 2021 10:09 AM
deathrider666
Sep 28, 2015 06:12 PM
