can you tow an escort cossie?
i would imagine you cannot due to the 4wd system/diffs etc unless you remove the propshafts.
got one in now with a bad vibration and have just found out he has attempted to tow start the car to get it running after a flat battery
not the best i would have thought
also there seems to be a lot of movement on the front prop before it moves the main prop-how much should there be
as long as all 4 wheels are on the ground and out of gear I dont understand what the issue would be..
Afterall- how does it get on a flat bed... its winched (read towed) up the flat bed.
Jake
Jake
yes ok,
but some 4x4's cannot be towed at all.
what is worrying me is the fact he has towed it down the street then bump started it whilst towing it as the car had a flat battery,which means it probably wouldnt have fired up straight away so would have been dragged along in gear until it fired up.
that is my concern that the shock could have put extra strain on something
Originally Posted by fordsportjay
yes ok,
I cant think of any manual 4wd that cant be towed just fine if all 4 wheels are on the ground.
ok-change question................
CAN YOU TOWSTART AN ESCORT COSSIE?
IE- TOW THE CAR ALONG THE ROAD,DUMP THE CLUTCH AND TRY TO GET IT TO START THAT WAY WITH A FLAT BATTERY.
would/could it do any damage?
Your guy is probably the first person "stupid" enough to attempt such a thing????????
Jake
there wouldn't be anything happening to the drivetrain that wouldn't happen during 'normal' driving anyway..
i mean slamming a 4x4 cossie into 2nd gear is where the problems start...a tow start is childs play lol
its just not something i would do to an escort cossie.i would much sooner charge the battery up then start it.
WHY?
WHY?
good point chip
no,i would charge the battery on that too
So really this topic should be titled
"Would you ever tow start a car" as the fact its an escos is totally irrelevant?
I would/have/do bump start cars but never ever consider towing... what a pain in the ass that would be.
When it comes to cossies or performance cars- charging the battery seems like a better plan?????
Jake
Originally Posted by rigwrecker
the only issue wi bump startin a car if the battery is dead now adays is if the imobiliser wont let u but any other time it wont hurt it
my mates turbo went straight through his rad
Only time bump or tow (they are both the same - just usually a bit quicker and longer) is an issue is when it won't start and has a cat. Chucking a load of unburt fuel at the cat will ruin it.
You won't wash the bores either unless you towstart for miles.
Just to clarify ONCE AND FOR ALL, the Escort can be towed
It even gives you instructions in the handbook on HOW to start it by towing or pushing
The ONLY proviso (as has already been mentioned) is that you must Never raise only one axle when towing.
Hope this helps
.It even gives you instructions in the handbook on HOW to start it by towing or pushing
.The ONLY proviso (as has already been mentioned) is that you must Never raise only one axle when towing.
Hope this helps
Hope this helps
Hope this helps
.The amount of people who never read the manual....
It also says in the Escort Cosworth Manual that there is NO performance advantage to be gained by running Super Unleaded.....
Originally Posted by toff
A know people who wont tow there Evo's or scobbys cause it says in the book not to
Never get tired of watching this
Though my mate was told when his Civic Type-R (54 plate) got towed by the AA that you can only tow it backwards (or maybe forwards.....either way, if you tow it the wrong way it fucks it)
Wouldnt it depend on which gear he tow started it in? If towd along then droped the clutch in say 1st or 2nd the torque would need to be quite high to turn the engine over....or maybe im wrong.
Hence why people leave there cars in st or 2nd when parked because its very hard to turn the engine with the car in a low gear.
I think tow starting at 70 and then uping the clutch in 5th would be ok, as the engine would only have to go to around 2500 revs.
But if the guy was towing at say.... 30 and droped it in 1st the engine has to shoot straight to around 6-7000 revs! massive brake on the transmission
Ive allways understood it as you should never really tow and especially tow something for any sort of distance that are either
A/ a automatic (auto box runs dry as the oil pump is driven from the front of the box)
B/ anything over 7.5 tonne (winds the diff or gearbox up depending on modeland make)
C/ 4WD ( as above but also chance of winding the transfer box up)
I don't understand the confusion here? Generally people tow start a car cause they are too lazy/weak/don't have enough people to push the thing! Its the same idea as a bump start.
i used to drive an astra van that i used to push and bump start myself lol it was a right pain havin to park hoping noone would park either side o ya
was glad when the new starter came home
