Removing core plugs?? how :cry:
Old Mar 19, 2007 | 01:31 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default Removing core plugs?? how :cry:
I need to remove a core plug from my Zetec, its already been built up but due to a farily large technical error on my part, i need to remove a core plug from where the original flame trap was and use it as a breather.
i have made a small hole in it and screwed in a self tapping screw, then gave it some with a claw hammer to try and pull it out.
basically i felt it give a little, so gave it another good hard yank and it wasnt the core plug at all, the fookin head of the hammer broke off
so now i have a core plug with a hole in it, and a fucked hammer.... how am i gonna get it out lol?
i guess i could drill it out, but will need to stick something up inside the block to stop the swarf going everywhere lol
Old Mar 19, 2007 | 01:34 PM
Physio's Avatar
Physio
I used to tap the core plug on the edge with a screwdriver & hammer & the top of the core plug used to swing out, then use grips & pull it out.
Old Mar 19, 2007 | 01:38 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Run the engine with no water, it'll get hot and they'll blow out
Turbosystems's Avatar
Turbosystems
Super Moderator
weld a bolt to it and draw it out into a large socket
Old Mar 19, 2007 | 01:42 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
radders
cheers for the more sensible replies lol
Tony, dont have/cant weld lol, so looks like its a hammer and screwdriver lol
Old Mar 19, 2007 | 01:45 PM
Physio's Avatar
Physio
Trust me it works
Old Mar 19, 2007 | 01:47 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you are supposed to bash the centre of the plug with a drift to deform the plug
then bash the outside to get it to swing out and then you lever the little shiney buggers out with a levery thing
what you aren't supposed to do is drill holes in the middle and use a claw hammer to pull them out, you seem to be watching too much discovery real time
Old Mar 19, 2007 | 02:06 PM
ballin's Avatar
ballin
galbally eat ur heart out
Old Mar 19, 2007 | 02:14 PM
Eagle's Avatar
Eagle
Super Moderator
Old Mar 19, 2007 | 02:26 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I normally get them out by the "hit them on one edge and then pull like fuck with mole grips and level them with a big screwdriver" technique too.
Old Mar 19, 2007 | 02:36 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cool, ill beat its ass later then
i got a big hammer that works lol
Old Mar 19, 2007 | 02:39 PM
Chip's Avatar
Chip
Old Mar 19, 2007 | 03:25 PM
dojj's Avatar
dojj
i thought dan was supposed to know this things? and aren't core plugs supposed to go in the water jacket? you make it sound like it's in the exhaust
Old Mar 19, 2007 | 03:40 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
see the core plug in the triangle shaped bit, thats the cunt im trying to get out
pee vee's Avatar
pee vee
how have you fukked it up fudge?
What do you need to use that hole for? lol
apart from the breather
Old Mar 19, 2007 | 03:41 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cunt
what arnt you at work?
get the kettle on for about 5!
Old Mar 19, 2007 | 03:46 PM
ricky_3dr's Avatar
ricky_3dr
What he said trust him, it works
Old Mar 19, 2007 | 10:30 PM
dojj's Avatar
dojj
strong magnet will have that out in second mate
Old Mar 19, 2007 | 10:41 PM
Physio's Avatar
Physio
You tell him
Old Mar 20, 2007 | 09:28 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
didnt get chance to have a go last night, so its tonights job lol
Old Mar 20, 2007 | 09:57 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
well, its out lol!
cheers to all that said to twat it with mallet and screwdriver!
it took about 20 seconds, no need for mole grips or owt either
just hammered the bottom, il flipped round, and levered it out from the top lol
job done
Old Mar 20, 2007 | 10:14 PM
Physio's Avatar
Physio
well, its out lol!
job done
Sorted!
Old Mar 21, 2007 | 09:55 PM
dojj's Avatar
dojj
well, its out lol!
job done
after your antics, no one is going to believe you without a pic of the removed core plug mate
Old Mar 21, 2007 | 09:58 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
he may have a pic of the block without the core plug in it...
but i bet he cant show us a pic of the core plug he took out, as its now in the block
Old Mar 22, 2007 | 06:06 PM
dojj's Avatar
dojj
i still can't work out who that plug is going to be a breather
for what?
only a swirl pot?
Old Mar 22, 2007 | 09:43 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
in the pic i posted, i got the machine shop to block that hole, this hole is the flame trap breather on a zetec.
i have removed it now, its in the garage but im not gonna be in work tomoz to bother to take a pic and upload if for proof
basically to make it into a decent block breather i will make a plate out of 4mm thick alloy sheet, then get a 90 degree alloy tube welded on to that.
hey presto, a take off for a block breather - is it really that hard to grasp the concept??
ps dojj, its not in the water jacket, with it removed its just a fucking great hole in the block
Old Mar 25, 2007 | 11:33 AM
dojj's Avatar
dojj
does this mean that YOU didn't remove it then and your "WORKING" excuse is so that you can buy a core plug from ford, bash it about a bit and then post it thus PROOVING that you removed it?
right, get a pic of it when it's in the car and we'll all give you a round of for getting that far with the build
Old Mar 25, 2007 | 12:29 PM
dojj's Avatar
dojj
and how is he going to attach the 4mm sheet to the hole then?
Old Mar 26, 2007 | 09:00 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
with the 3 bolts you cunt
need to do similar for the thermostat too lol
Old Mar 26, 2007 | 10:21 AM
jdfiesta's Avatar
jdfiesta
Old Mar 26, 2007 | 10:30 AM
Chip's Avatar
Chip
Sounds like a good plan Dan, too many people ignore the importance of good crankcase ventilation IMHO
Old Mar 26, 2007 | 10:33 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
Old Mar 26, 2007 | 10:46 AM
dojj's Avatar
dojj
no witty comebacks from me as i can't see the pic at work but i'll be sure to check in when i get home
Old Mar 26, 2007 | 11:10 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
Old Mar 26, 2007 | 11:13 AM
Chip's Avatar
Chip
Old Mar 26, 2007 | 12:04 PM
dojj's Avatar
dojj
knowing that i can't see the picture, thats probably soemthing either really great or really shit
Old Mar 26, 2007 | 05:17 PM
dojj's Avatar
dojj
now i'm home can i call you a cheeky fucker chip
and fudge, still can't think of a witty reply
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
grishenko45
Sep 9, 2015 12:58 PM
stevierob
Sep 7, 2015 07:09 PM
hopper350
Sep 4, 2015 12:53 AM
