ABS
Mar 19, 2007 | 08:43 AM
ABS
Hi guys. Just wondered if anyone knows of an ABS removal guide? Looking to remove the ABS on my mates S2 to fit the rear disc conversion. Cheers fellas
Mar 19, 2007 | 06:16 PM
I removed my abs mate but no nothing about rear disc conversion.
Mar 20, 2007 | 02:29 AM
try
www.rsbible.co.uk think its on here
Mar 20, 2007 | 08:42 AM
cheers fellas
Mar 20, 2007 | 12:31 PM
When the ABS has been removed and rear discs fitted, has anyone found it overbrakes on the rear/tries to change ends? heard conflicting stories
Mar 20, 2007 | 06:04 PM
I think I must be in the minority of having a S2 which still has ABS!
Mar 20, 2007 | 06:08 PM
Do a search there is millions of threads on ABS removal. Easy enough to do
grey RS , i think the majority would agree with you there. Ive fitted them to my car and done about 2 miles since so i can't comment, but being as mines a hairdressers car and quite arse heavy i doubt ill have problems.
Above all though, i doubt i would fit them again
Mar 21, 2007 | 09:12 AM
The general consensus is you must put a restriction in the line on the rears, but Tim hasn't on his and you must have seen him on track in his grey s2 at some point - didn't seem to have any problems lol!
ps i also don't think they are gonna make a great deal of difference, we will see
Mar 21, 2007 | 09:40 AM
Quote:
Ive still got mine and to be honest i dont see a problem with the ABS mine works fine
Mar 21, 2007 | 10:39 AM
Took mine off as it never really worked properly and made the pedal feel spongy. I never noticed this until i drove an s1 without it
Mar 21, 2007 | 02:48 PM
Lets get not start picking faults in your car we might never end
grey RS , thats what ive heard generally, i think ill be lucky though the roof weighs a ton lol! Plenty of weight
Mk3 & 4 brakes in general are just rubbish, i'm looking to substantially alter mine one of 2 ways, if i can ever be arsed to pull my finger out
Mar 21, 2007 | 02:59 PM
How did i know you would be bitching
Id list the problems on your garden ornament/car
but then we would end up with a 30 page thread
Mar 21, 2007 | 03:02 PM
Mar 21, 2007 | 03:11 PM
Yeah but atleast i can use mine not just push it in and out the drive
Mar 21, 2007 | 03:32 PM
Mines starts and runs, could go drive now if one was to feel so inclined
Mar 21, 2007 | 03:47 PM
Mines starts and runs, could go drive it now if i was inclined to have a walk back home when it had broken down
Is that what you were ment to type
Mar 21, 2007 | 03:51 PM
Mines starts and runs, could go drive it now and not have to worry about having to walk back home when it had broken down like SOMEONES
No thats what i wrote
Mar 21, 2007 | 04:12 PM
meanwhile, back at the topic.....
do u ditch the distrubutor/regulator thingys on the inner wing when u lose the abs..??
Mar 21, 2007 | 04:46 PM
On the inner wing?
The T pieces?
Mar 21, 2007 | 04:53 PM
I still have my ABS connected with no problems
Mar 21, 2007 | 05:00 PM
On the inner wing?
The T pieces?
thats em...
Mar 21, 2007 | 06:02 PM
Nah you'll need them still, they split the pipes up so you have a pipe for each brake
Removing the rear load valves on the wishbones is a good move though
Mar 21, 2007 | 06:11 PM
on the to do list...
been given a rear disk conversion anyway, mite as well use it!!!
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
