S1 brake conversion
2wd discs and calipers wont fit behind standard rims cos they are 4 pots, 4wd calipers with 2wd discs will. Theres many options for the front.....
As for the rear, i'd probably suggest standard series 2 drums if you can get your hands on some
Have to agree with Alex_86:
https://passionford.com/forum/viewtopic.php?t=248404
If I were to do it again tho, I wouldn't go for the ferodo pads, I'd try mintex. My Ferodo ones squeel like a load of pigs when cold, not a good image on the work run!!!!
Lee
Lee
