300mm st220 brake calipers
i have a good pair of mondeo st220 brake calipers, pads, brake pipes and mounting bolts.
which when used with st170 focus brake disc's are a direct fit onto mk5/6 escorts.
mk4 escorts need the caliper spacing accross 8mm i believe by using spacers.
you just need a 12mm drill bit to clean out the 10mm holes.
the mk5 needs different brake pipes.
the mk3/4 can use the standard pipes.
disc's are quite cheap on ebay now.
pics soon
£99
essex
pics soon
£99
essex
