Diff and Gearbox Questions
Old Mar 17, 2007 | 07:31 PM
S1_RST's Avatar
S1_RST
Default Diff and Gearbox Questions
3 weeks ago i was cruising home from my mates place in my S1 RST when i accelerated gently away from a roundabout and i heard a clunk and then a whirring sound. Then i lost what i thought was the clutch as i could rev and rev but the car would not move.
I could move into every gear but would not engage etc.
Well after sourcing parts i have now changed the Clutch and flywheel and bolted everything back together and got the damn pedal cable back on.
I put the car in reverse and moved it back and went to drive it forward in 1st and a few metres down the road i hear a Clunk and now im back to square one.
Cant be the diff can it? or maybe the drive shaft?
any ideas help is welcomed guys......
Old Mar 18, 2007 | 12:28 PM
JesseT's Avatar
JesseT
Well was there anyting wrong with the clutch to begin with? Sometimes driveshafts can pop out of the gearbox and cause someting like this.
Old Mar 18, 2007 | 07:16 PM
S1_RST's Avatar
S1_RST
After replacing the clutch i could tell it needed doing sooner or later anyway.
Something deffinitely broke inside - maybe eth box as all i heard was a bang and then a "ding" ding" ding ding ding sound and lost all drive!
Ive checked the driveshafts by doing the following :
1 person looking at the inner driveshafts to see what moves when the other person puts the car in gear and tries to drive it .
Results : Nothing was moving but you could hear the gears whining.
Could this be the Diff? or a foo**ked gearbox.
Are there any gearbox exchange places i can go to if this is the case OR
What other boxes would fit my S1? maybe a s2?
Old Mar 18, 2007 | 10:53 PM
NUTS RuS's Avatar
NUTS RuS
Deffo sounds like a box problem
Old Mar 19, 2007 | 10:26 AM
zippyobrien's Avatar
zippyobrien
my si did this when the front arms wore out so much the drive shaft popped out the gear box, same noise as you describe,
yatta
May 21, 2016 10:31 PM
mark r
Sep 29, 2015 07:27 PM
Kam B
Sep 24, 2015 10:40 AM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
