what wires do you need to connet to get a rst going
wel if u can get a rst loom all u have to do is cut the wires for the rear lights on the loom and join them to the vans rear lighting part of the loom normally near the driver side behind the speaker cover and then feed the fuel pump wires to the under side of the car and get a tank to fit there or simply make ur own mounts
hope this helps matey
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
