rs1600i same as rs turbo head
Old Mar 15, 2007 | 10:37 PM
scotty86d's Avatar
scotty86d
Default rs1600i same as rs turbo head
as above
Old Mar 15, 2007 | 10:50 PM
Rs Baz's Avatar
Rs Baz
i beleave the rs 1600i head has bigger valves
Old Mar 16, 2007 | 12:24 AM
homer j's Avatar
homer j
if i remember correctly it did have 1mm bigger valves. they were also sodium filled i think. it was generally a better head from the factory than the other cvh heads were.
Old Mar 16, 2007 | 04:50 AM
Alex_86's Avatar
Alex_86
rs head valves are also sodium filled.... but yes rs 1600i have bigger valves
Old Mar 16, 2007 | 11:46 AM
smitsturbo's Avatar
smitsturbo
i thaught only s1's had sodium filled valves
Old Mar 16, 2007 | 09:01 PM
XR2's Avatar
XR2
Yes, on the outlet side. RS1600i didn't have them
Old Mar 16, 2007 | 09:48 PM
SafeChav's Avatar
SafeChav
The RSi head also has the round exhaust ports, one of the best flowing heads i believe.
Ask in the RSi section they will have a better answer in there for you i expect
Old Mar 17, 2007 | 12:14 AM
sm's Avatar
sm
16i heads have bigger valves, round exhaust ports, special cam, adjustabe tappets instead of hydralic lifters
they were basicly detuned race cars with konis, 4 branch manifold, shame they used xr3 brakes
the race cars used to make 160bhp on a dizzy instead of the production 16i's twin coils, the ecu was modded too
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Marcus L
Aug 29, 2015 02:18 PM
IAN RS2k
Aug 18, 2015 07:51 PM
