urgent help airbag light staying on
Old Mar 8, 2007 | 06:46 PM
Rs Baz's Avatar
Rs Baz
Default urgent help airbag light staying on
can anyone help for the second time ive re booked the car for its
m.o.t tomoz {friday} and the bloody airbag light is staying on now
the car is a L reg astra also the horn dont work ive had the steering
wheel of to check all contacts, when i start engine up the airbag light
goes out then come's back on, if i press the horn the relay clicks
but horn doesnt work and i do have live to it when its pressed,,,,,,,,,,
Old Mar 8, 2007 | 07:04 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
air bag light is not a fail
Old Mar 8, 2007 | 07:05 PM
RS SAMA's Avatar
RS SAMA
i dont know about the horn but my car passed its taxi test last week with its airbag light on, the tester said its not part of the test so i wouldnt worry about that but it will fail if the horn isnt working but good luck any way.
Old Mar 8, 2007 | 07:09 PM
rssteve's Avatar
rssteve
just put an air horn on the dash should pass then i think?
Old Mar 8, 2007 | 08:31 PM
Rs Baz's Avatar
Rs Baz
spot on thats the reply i really wanted because its going for a test to
be used as a taxi car
i will just sort the horn out then
Old Mar 8, 2007 | 08:33 PM
Rs Baz's Avatar
Rs Baz
i will fit a diffrent switch to the dash for the horn
i think its the dam module behind the steering wheel it must be an earth
i will try fitting an earth to the battery first then see what happends...
it has live when i press the horn but it doesnt do anything
SMILER258
Sep 28, 2015 09:04 AM
cossiestu
Sep 19, 2015 05:19 AM
Flatlinedan
Sep 18, 2015 12:41 PM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
The Enigma
Sep 12, 2015 10:12 PM
