what clutch for 330bhp 4x4 cossie?
Shop around if you want the cheapest.....
Mike R's prices are good, and the service is excellent. Don't forget you'll need to get your flywheel surface ground/refaced before using a paddle clutch. A new cable and release bearing would be a good idea too.
Also std Ford covers aren't as good as they used to be apparently, the full kit (paddle) ain't that bad once you get used to them (imo).
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
