anyone know about ford 1.8d engines
Old Mar 7, 2007 | 05:51 PM
cossiegreg1's Avatar
cossiegreg1
Default anyone know about ford 1.8d engines
the one thats in my n reg van. it used to start mint.On a morning i would give it a couple of heats and it would fire mint,it still does now. but before, when it had been fired up,if you finished your journey,then came back 2/3 hours later it would fire sraight up.
Now you have to give it 2 heats then it turns for quite a few seconds then fires (a bit of smoke,never used to). but if i give it 1 heat, then wait for the click, it fires within a second of turning the key.
I have changed glow plugs,Diesel filter,And put in some diesel and injector cleaner.... Any ideas?
Its not a major problem but its buggin me why its not like it used to be
Thanks greg
Old Mar 7, 2007 | 07:59 PM
cossiegreg1
Old Mar 7, 2007 | 08:05 PM
gup's Avatar
gup
is your starter motor turning over fast or slow fella could be this as then thier is more fuel and air in the chambers before it ignites mines doing the same too
Bailes1992
Aug 16, 2015 07:14 PM
