YB oil pressure - seems a bit low ?
40 psi on start up
20 psi on idle once fully warm
about 30 - 35 psi driving at about 1.5k rpm once fully warm
40 - 45 psi when giving it stick and fully warm.
About right or a bit low
(ps it is on a Tim electric gauge so not sure how accurate these are)
Engine is 102k miles stage 1. Never been rebuilt.
is a bit low on higher revs by the sound of it...
20 psi is a bit low on idle too.
check with another gauge to rule that out but if its the same, it means the engine is stating to wear i think.
mrmann
Aug 20, 2015 11:24 PM
ekjim
Aug 17, 2015 08:57 PM
change it!
