would changing exhaust pipe angle effect power
Old Mar 6, 2007 | 08:56 PM
abdr500's Avatar
abdr500
Default would changing exhaust pipe angle effect power
changing the angles of the exhaust does it affect power same exhaust box used but a better fit with slightly different angles
Old Mar 6, 2007 | 09:31 PM
rapidcossie's Avatar
rapidcossie
smoother path will mean less restriction...
Old Mar 6, 2007 | 09:36 PM
chRiS Turbo's Avatar
chRiS Turbo
Can't see it making masses of difference, but it would change the tone of the exhaust more if anything. So long as you don't direct the gases back towards the front of the car at any point, you shouldn't loose much if any power.
Old Mar 6, 2007 | 10:49 PM
abdr500's Avatar
abdr500
this is what I was thinking as the gases all ways find there way out I have mad slight alteration to my ex system and its now perfect fit so in fact I have got ride of a 90% bend and now replaced with a 45% bend but the rest of system had to be modified to accept the more striate exhaust system
CossieRich
30
Sep 8, 2015 10:08 PM
YODI
Aug 30, 2015 01:12 PM
cameron2
Aug 25, 2015 07:18 AM
track.focus'd
Aug 12, 2015 05:53 PM
