pc peeps plz look(urgent)
Old Mar 6, 2007 | 07:45 PM
392B.H.P.SAFF's Avatar
392B.H.P.SAFF
Default pc peeps plz look(urgent)
cant get my mates pc to work it fires up then comes up with the message
ntldr missing?
any ideas
thanks
Old Mar 6, 2007 | 07:49 PM
Drewman's Avatar
Drewman
Could be a number of things...
http://www.computerhope.com/issues/ch000465.htm
Old Mar 6, 2007 | 09:02 PM
collierm's Avatar
collierm
MP for K.I.S.S
Take the floppy disk out the drive.
Old Mar 6, 2007 | 09:25 PM
RANJ's Avatar
RANJ
check floppy drive and cd drives, else it reinstall windows time
Old Mar 6, 2007 | 09:58 PM
TrevCannon's Avatar
TrevCannon
NTLDR! im thinking that comes up on the black screen where it boots? should do anyway because i was manually deleting files cleaning up my a hd & had the comp running for a hour more then had to reboot & that came up!!! hd useless without the file i had to reinstall xp but i still got all the personal stuff, tunes, photos & what not on it maybe did it a certain way i duno
Old Mar 6, 2007 | 10:19 PM
orionmojo's Avatar
orionmojo
yeah you installed it 'over the top'
i.e, you didn't reformat the drive.
ntldr is a pretty vital file and if it goes it could be bad news for the hdd and could be dying. i'd get it backed up just incase. anyone with abasic computer knowledge should know how to do this. if its an IDE drive (40 pins at the back) rather than a SATA (small electrical contacts) then its the same fitment as your CD drive, unplug the cdrom drive and then boot the machine with both hdd's attached. simply copy the data you want onto the working machine for safe keeping. seriously though, take reasonable care, i make it sound really easy, and it is once you've done it a few times though. there should be a notch on the ide cable so you can only plug it in one way, if not the red side goes to pin 1.
cossie362
Oct 11, 2015 03:53 PM
paceo
Sep 25, 2015 08:05 PM
paceo
Sep 17, 2015 12:12 PM
