clutch help
After ive been drivin @ 80 or so for a while on a motorway when i come to a slip road and go to change down thru the gears it is impossible to get it into any gear unless i slam my foot down on the clutch pedal
anyone got any ideas wot could be causing this?
thanks
Scott
thanks
Scott
Not really sure on the best way to check it, I'm sure the RST boys will have some input. The ratchet should be self adjusting - try pressing the clutch pedal a few times and seeing if it clicks, or you may feel it adjusting. You can do this whilst stationary.
For what it's worth, I always change the clutch cable when I have a new clutch.
You could get a mate to watch the clutch lever/arm on the box whilst you press the clutch pedal in, and see if it has full travel.
Of course it could also be something else, but nothing springs to mind at the moment.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
