focus 1.8 white smoke
ok this is a new topic probably shouldnt be but solved some issues in other topic so have just the 1 issue to solve
issue is steam coming out the exhaust when rev engine it leaves a puddle only small but leaves puddle on the floor and i get a fair bit of steam well noticeable now there is no oil in water or water in the oil have loads of compression spark plugs all fine engine running sweet or seems to be
changed maf idle control valve due to other issues i could understand headgasket etc if was using water or oil and water were mixed etc but not seen this kinda issue b4 took the car on a run no difference
any suggestions?? at a loss now as to know next step to try
there is a lot ive looked at it stuck fingers up exhaust nothing oily just water going to get some 1 to test it fer headgasket incase m8s m8 has a garage so he going to see him but thats the only other thing havent checked is lambada sensor
am i correct in saying thats the 1 thats on the cat front of engine thats a bugger to get out?
many thanx
many thanx
yes mate thats the one,
try unplugging it, if u get even more white smoke then its working. if it doesnt make any diff to the smoke then ya need a new one or check wiring to it
aye thing is tho zvhurst mentioned testing the sensor to which i have done the way he says and it makes no difference with the sensor plugged in or not he says should get smoke if disconed im assuming that because theres no change as he sugests and im testing it correctly i hope im assuming then that the lamba or o2 sensor jobbie is screwed
oh and btw cozzie dave if thats middleton as in leeds you aint far from me if so do u know any decnt breakers that have focus bits in cos thorpe lane aint got f*** all lol
also if your after spares
FORD SALVAGE in barnsley is my local breakers that my mate runs
01226 717401
cheers dude ill get round to giving him a ring just got m8 sorting sum 1 to leak test and then will renew the lambda will give youre m8 a ring barnsley aint that far away from me cheers
well aquired some of that leak test fluid only 5.99 from fleabay
made meself a testbottlen adaptor for header tank ran engine to temp slapped me tester with dye in to header tank and tested for 7 mins did this twice and dye remained blue so can now rule head gasket out
assuming also can rule manifold gasket out 2?
only thing left is what we talked about before the lambda sensor so
hunting around for lmabda sensor gonna try youre m8 again zvhirst as he dint have last week when rang thanx again tho
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
