rs 500 intercooler
Mar 5, 2007 | 09:18 PM
rs 500 intercooler
Mar 5, 2007 | 09:20 PM
looks like it sweld up and split get it weldid if you want a cheap fix .mind it is close to the core
Mar 5, 2007 | 09:26 PM
what you doing with the old one?
Mar 5, 2007 | 09:27 PM
rs 500 intercooler
Bit close to the core for for a weld I thought too its on a track car runing 28psi don't wont the hassel
Mar 5, 2007 | 09:53 PM
I am told that the Forge ones flow better - I also have a pace, but at that time, didnt realise there was much of a difference.
FF did an article on them a few years ago - the original one came out on top by quite a big margin, then the Forge, then Pace.
JJ
Mar 5, 2007 | 09:55 PM
Pro alloy are tested to 100 psi.
Mar 5, 2007 | 09:56 PM
so what you doing with the old when you replace it?
if selling how much as could get it welded mine only run 20 psi.
Mar 5, 2007 | 10:03 PM
That's not the first Pace one I've seen do that.... saw one similar to that this weekend as it happens.
Was it an old one?
Si
Mar 6, 2007 | 03:22 PM
rs500 intercooler
The cooler is 2 years old done less than 10,000 miles, My mate is a welder and is going to fix it and use it him self
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
