Collins Ecu fitted and mapping started(updated)
Just heard from Alan at AVA and they have fitted the new Collins ecu to my car and started the mapping, Alan recons it is prity good software. He is still working his way through the features and getting to grips with them but things look to be going well.
They have done one low boost run up stopping at 7k and the car made 241 ATW at 1 bar on the T38 , 20 brake less that it made last time it was ran there on a T35 at 2 bar. Plans now are to dial in the cams and finnish the mapping to a 7500 rpm limmiter then raise the boost to around 2 bar.
Cant wait to get it back just need to get some diffs sorted out now.
No chance of it being at crail i dont think. We may have a problem with the oil pressure Alan wasnt too happy with it when playing with the idle speed. Was like the oil thined out alot when it got up to real high temp .He phoned to let me know before going any further ,so plan is to change oil to the Castrol Rs that they use and try it out if not will need to look further into it.
Hope the oil change will sort the pressure problem out then Alan can get the cam timing done. Will be good to see what sort of change the cam timing will make since most people slag BD10's. If i get anything over 310 ATW will be happy aslong as it drives well, just a pity wont have it for crail as its nice and close .
Originally Posted by dovboy
i thought you were going to go with a t34 neil?
are you still going to crail without the escy?
Got a UT T38 so switched from the T35 as the one i had was a .55 housing, should be good for 400+ with lowish lag.
Think after this i will be getting Marco to sort my diffs out then that will have to be it for a while as just bought a house
Just want it back to get some miles on it has been about 6 month since i have had it on the road properly.
Originally Posted by col cos1
sama as mine except ive only the back box,and its ten years old and next to none baffel left in it
its now the restricting part in my car at this poer level
Originally Posted by CharlieSaff
360ATW is my guess
Just heard from AVA and the oil change has sorted out the oil pressure problem
. Alan has now set the cam timing and did a power run at .7 bar making 231 ATW ,so just a few other small bits to mess with then then go on with the full boost set up and finnish the idle map. So things are looking up and the ECU is looking to be a good bit of kit.
The one i have is the same spec as the UT unit but built by the guy that use to work for them then set up on his own(Vince i think), its has also got the internals pollished to try and aid flow.
I've only drove the car through to AVA with the T38 fitted but since it was on the old T35 map was trying to keep it off boost.
. Alan has now set the cam timing and did a power run at .7 bar making 231 ATW ,so just a few other small bits to mess with then then go on with the full boost set up and finnish the idle map. So things are looking up and the ECU is looking to be a good bit of kit.Hi mate glad to hear your oil pressure is sorted what grade and make was your old oil??
saff is working!!!...atm
[/quote]
The oil that was put in originaly was Valvoline 10/50 i think, pressure was ok to start with but the oil seemed to thin out alot when real hot. AVA have now changed to Castrol Rs 10/60 and seems alot better , didnt drop pressure while doing the cam timing when it was on the rollers for long periods of time.
[/quote]The oil that was put in originaly was Valvoline 10/50 i think, pressure was ok to start with but the oil seemed to thin out alot when real hot. AVA have now changed to Castrol Rs 10/60 and seems alot better , didnt drop pressure while doing the cam timing when it was on the rollers for long periods of time.
Thanks Neil
Bet you cant wait to get it back mate it will fly
Speak soon
No probs mate . Yes cant wait to get it back , need to get my finger out and sort out some uprated diffs as its standard ones in it justnow.
Will keep an eye out for it at the shows this year always had a soft spot for your car
credit to you Neil
Originally Posted by dake205
should make well over 300 close to 350 on collins mate mines running collins and made 314atw at dastek with t34 and still got slight boost leak good luck
Originally Posted by glancy2081
glad to see it was just the oil neil
