cossie spares/parts----------updated 12/3/07 (PARTS ADDED)
few cossie parts for sale removed from my 2wd sapphire:
parts in green are possibly sold
parts in red are sold
t34 turbo, -31, excellent condition £395
pace rs500 intercooler, vgc £220
pro alloy radiator, 2 months old £250
4x dark green injectors (803's) £100
3 bar map sensor £40
4x4 dark lamps £25
4x4 moonstone bonnet £140
throttle body £50
idle control valve £30
4wd throttle position sensor £35
2x 2wd throttle position sensor £25 each
level 1 ecu, stage 1 chipped £95
level 6 ecu, chipped to run t34, greens, 3 bar, -31 etc £120
scorpion exhaust system, nearly new £250
k&n panel filter £10
2wd head complete (cams, pulleys, valves, tappets etc etc) £325
complete 2wd inlet plenum+elbow £45
fuel rail including clips, pipes, fuel regulator £35
2wd exhaust manifold (both bits) will not split £60
distributor complete (leads, cap, rotor, phaze sensor) £60
crank shaft £200
4x con rods £60
4x pins £25
4x pistons (valve cut outs) £200
crank pulley x2 £15 each
2wd sump £35
rocker cover £40
water pump x2 £10 each
aux shaft x2 £15 each
205 block £80
2wd flywheel £60
2wd modine oil cooler £10
2wd front aux bracket/cover (alloy) £15
block breather adapter £25
2x 2wd clutch, used but good condition £20 1 left
2x turbo oil feed pipes £20 each
roose sport boost hose set (blue) brand new £90
2x engine mount arms £10
2x engine mounts £20
standard dump valve £10
alternator £20
stainless ignition amp bracket (rs logo) £10
stainless bonnet stay £10
stainless coil surround £10
abs sensors x3 £10 each
rear lamp foams £3
s2 alloys + tyres x5 £150
s2 88'spec front seat £20
s2 90'spec rear seats £10
s2 90' spec front seat £50
loads of pipes, brackets, clips, connectors etc, just ask i may well have it
WANTED:
SET OF DOOR RUBBING STRIPS OR JUST THE 3 FOR DRIVERS SIDE
open to serious offers on most parts
pm me for any more details or questions
more parts will be added here and there so keep a look out
cheers for looking
4x4 dark lamps £25
throttle body £50
crank shaft £200
4x con rods £60
4x pins £25
2wd sump £35
rocker cover £40
205 block £80
2wd flywheel £60
alternator £20
rear lamp foams £3
WANTED:
cheers for looking
