my cars gone pants.....again
Old Mar 4, 2007 | 06:43 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default my cars gone pants.....again
had an air leak on the inlet manifold..must have been there for ages but never noticed as the car always ran sweet and idled loverly...
fixed the air leak ,now the car idles shite ,fine with the iscv off ,but even with the car hot, the iscv is holding the idle up
doulble checked all plugs on well, and no air leaks at all now, tested it to 2 bar.
the secs monitor is showing good results.... and im getting good voltages from the lambda
and the car is using more fuel than normall too
its a L8 closed loop cossie btw
Old Mar 4, 2007 | 06:53 PM
xr4x4rs's Avatar
xr4x4rs
was the car set up with teh air leak?
as the the tick over could of been adjusted to compensate
Old Mar 4, 2007 | 08:03 PM
JTECH James
Passion for Fords!
ive set it up after ,but it isnt right
Old Mar 4, 2007 | 08:20 PM
Jay,'s Avatar
Jay,
Sponsor
also check the idle fueling as itll be very rich to , so set that up then recheck idle hth
Old Mar 4, 2007 | 08:24 PM
JTECH James
Passion for Fords!
done that... started with the 5 turns in ,then two turns out method...set it to .9%
the iscv should have no effect on idle when the car is hot... but mine does, i think this is a tps fault?
Old Mar 4, 2007 | 08:25 PM
Jay,'s Avatar
Jay,
Sponsor
have you tried resetting the ecu ?
Old Mar 4, 2007 | 08:28 PM
JTECH James
Passion for Fords!
how do you do that?
Old Mar 4, 2007 | 08:29 PM
Jay,'s Avatar
Jay,
Sponsor
unplug it from the harness then plug it back it in
Old Mar 4, 2007 | 08:30 PM
JTECH James
Passion for Fords!
ahh will that make a difference?
Old Mar 4, 2007 | 08:32 PM
Jay,'s Avatar
Jay,
Sponsor
well should reset all the fault codes and errors
Old Mar 4, 2007 | 08:35 PM
JTECH James
Passion for Fords!
the fact its using loads of fuel indicated to me its not in closed loop ,even though the secs monitor is giving me good feedback, this doesnt mean its working.... the lambda is surging as it should... but the ecu may not be going into closed loop.
ther are loads of things it could be.... map sensor ,wiring loom fault...tps
Old Mar 4, 2007 | 08:37 PM
JTECH James
Passion for Fords!
fuel pressure is 3.5 bar at idle with the pipe off
c.o at idle .9%
Plug gap .65
secs is showing all good figures as normal
No air leaks tested to 2 bar
ive checked all these...must be electrical
Jay,'s Avatar
Jay,
Sponsor
just try it
Old Mar 4, 2007 | 08:38 PM
JTECH James
Passion for Fords!
i will thanks for your help mate
Old Mar 4, 2007 | 08:39 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
I've got a wideband lambda kit you can borrow if it helps at all James... see what your AFRs are up to...
You'll need a new lambda sensor boss though...
Hope you get it sorted, your car was flying a dew weeks ago
I also have a brand new TPS you can test on the car if you want.
Si
Old Mar 4, 2007 | 08:41 PM
JTECH James
Passion for Fords!
your a star si! its going really well now... just using more fuel than normall and not idleing as i want it to
got a black scorch mark on the rear bumper which isnt like this car at all even after a 160 banana per hour escapade yesterday
maybe its supposed to be like it is ive just always had an air leak
hows yours?
Old Mar 4, 2007 | 10:43 PM
Si B's Avatar
Si B
Mine's in Blackpool, so I don't know
It made it there though
Will await many phone calls from Mr Stu advising me on what bit has fallen off next!
I can bring the wideband down tomorrow if it will help.
Just realised I've fooked up with the TPS - it's in my Cossie with Stu as a spare in case mine plays up. Sorry about that.
Still Trev and Richie have working ones (I'd guess) that they could lend you just to eliminate that item from the list of potential issues.
Si
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Bailes1992
Aug 16, 2015 07:14 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
