Who sells a complete kit to relocate phase sensor to cam
Old Mar 4, 2007 | 05:25 PM
stevieturbo's Avatar
stevieturbo
C**t
Default Who sells a complete kit to relocate phase sensor to cam
As title
Who sells a kit of all the essential parts required to relocate the phase sensor to the camshaft ?
Cheers, Stevie
Old Mar 4, 2007 | 06:21 PM
banhambuilt's Avatar
banhambuilt
i would like to know also
cheers
dave
Old Mar 4, 2007 | 06:22 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Mountune
Old Mar 4, 2007 | 08:08 PM
GARETH T's Avatar
GARETH T
i think brom was selling it
its not that hard to make if you can do a little machinging, and have the wrc manual
Old Mar 4, 2007 | 08:29 PM
Alg1k's Avatar
Alg1k
off topic
Stevie what powers your Granada
Old Mar 4, 2007 | 08:39 PM
saph4be's Avatar
saph4be
how much are there any benefits fgrom this
Old Mar 4, 2007 | 08:56 PM
JjCoDeX75's Avatar
JjCoDeX75
Out of curiosity, what is the benefit?
Even if you are converting to wasted spark, why not leave the phase sensor in the dizzy?
Genuine question
JJ
Old Mar 4, 2007 | 08:59 PM
K.Goa's Avatar
K.Goa
I guess it`ll be more accurate, as there usualy is a bit of play in the dizzy-arrangement
Old Mar 4, 2007 | 09:03 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
The only benefit on a road car is the extra bling value
The Grp A / WRC cars had it relocated so its less prone to getting wet when they are going through water splashes etc.
The cam trigger, sensor and sensor holder costs about £120 from Mountune.
You then need to have the inlet cam and the cam cover machined, about £80.
Then you can remove the dizzy and replace it with a billet oil pump drive or just leave the dizzy in place. Billet oil pump drive is about £85-£100.
See my post for futher info
Which i need to finish
https://passionford.com/forum/viewto...asc&highlight=
Old Mar 4, 2007 | 09:08 PM
stevieturbo
C**t
Genuine question
JJ
ive told the owner that....but he reads too many magazines, and he wants what he sees in the mags
It certainly wont make a car go any faster, thats for sure.
Old Mar 4, 2007 | 09:09 PM
stevieturbo
C**t
Seen the post...good write up.
Old Mar 4, 2007 | 09:11 PM
stevieturbo
C**t
Originally Posted by Alg1k
off topic
Havent a clue TBH. It made 735hp at the hubs in June last year. I'd say that is conservative though, as I had to pull loads of timing out to actually get a smooth run on the dyno.
The dyno didnt seem to like it.
Also been a few changes since, then, and more currently in progress.
Old Mar 4, 2007 | 09:12 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Genuine question
JJ
Honestly its a waste of money Would be better off getting a new engine loom or put the money towards a Live Map
Old Mar 4, 2007 | 09:30 PM
Alg1k's Avatar
Alg1k
off topic
NICE
Old Mar 4, 2007 | 09:44 PM
stevieturbo
C**t
I know it is....
Engine loom is fine, and its on a Haltech
But there are far more important things to spend money on as you say.... Head, cams, manifold, T61, fitting GTR gearbox to name a few
Getting there slowly but surely though
Old Mar 4, 2007 | 10:24 PM
roop's Avatar
roop
does the cam trigger have to go on the inlet cam or can the exhaust be used,looking to use cossie management on different engine
Old Mar 4, 2007 | 10:34 PM
stevieturbo
C**t
Shouldnt matter which cam.
Old Mar 5, 2007 | 09:07 PM
roop's Avatar
roop
cheers!
Old Mar 5, 2007 | 09:08 PM
Billabong's Avatar
Billabong
I'd have thought you're better off having the cam trigger etc. on the colder side of the engine for reliability, if you have the option?
Old Mar 5, 2007 | 09:51 PM
JjCoDeX75's Avatar
JjCoDeX75
Tis funny what we all end up doing in the name of 'improvement'!
I always fancied changing mine over for aftermarket management with a more accurate engine speed sensor (a 31tooth job), but to be honest, I think that the L8 is doing a pretty good job so far, and with modern software these days, I havent outgrown it
JJ
Old Mar 5, 2007 | 10:07 PM
Kevin Sharp's Avatar
Kevin Sharp
off topic..stevie are you still wanting that flywheel?
Old Mar 5, 2007 | 10:22 PM
Rippers's Avatar
Rippers
Monte Geek
Did you see Franco's ?
Old Mar 5, 2007 | 10:23 PM
CozzyBrom's Avatar
CozzyBrom
had a few newer ideas
running off the aux pully and also flywheel pegs bolting into the back plate not suitable on 4x4 cars thow
Old Mar 5, 2007 | 11:04 PM
stevieturbo
C**t
Yes....
although I had Crail noted for the 25th......I have just been informed its the 18th now !!!!!!!!!!!
i'll be trying !!! that lost week could really mess things up
Old Mar 5, 2007 | 11:05 PM
stevieturbo
C**t
Brom, do you offer a kit of the parts to do the sensor relocation ?
Old Mar 5, 2007 | 11:07 PM
CozzyBrom's Avatar
CozzyBrom
yes still got parts pm me
Old Mar 5, 2007 | 11:15 PM
The DIVA's Avatar
The DIVA
One of the Brom`s conversions on my Escos....
Look good and works mint....
manuel boeckx
13
Oct 3, 2015 02:29 PM
yatta
Sep 1, 2015 11:28 AM
Anutternutter
Aug 21, 2015 06:07 PM
muz
Aug 16, 2015 12:57 PM
Zoggon
Aug 10, 2015 10:39 AM
