ST170 gearbox in a Mk4 Escort.....
Old Sep 11, 2004 | 02:49 PM
MadMac's Avatar
MadMac
Default ST170 gearbox in a Mk4 Escort.....
Anyone done it?
I know it can be done, just a case of fabricating the mounts....
be good for a laugh on a 2.0 Turbo wouldn't it
Old Sep 11, 2004 | 03:50 PM
AndyRST's Avatar
AndyRST
The gearing is all wrong for a turbo engine, you wont get the best performance from the engine to the road using that gearbox. The ST170 box is designed to help a N/A engine in the areas it loses out to a turbo engine
Now the Focus RS box theres a different story
Old Sep 11, 2004 | 03:59 PM
MadMac's Avatar
MadMac
yeah bit I luve the idea of a six speed shifter, and atm I can't see any other way of doing it.
Besides, once the engin is all set and build I think I might get bernie to make some custom ratios to make full use of it. 5 accelerating gears, on long top speed gear.
Thing is the car is to be sprayed in Feb/March, so it will need fitting at the same time so I dont ruin the new paint job.
Old Sep 11, 2004 | 05:13 PM
AndyRST's Avatar
AndyRST
The St170 box has 2 layshafts so it keeps the gears 1st, 2nd and 3rd normal spacing and then uses 4th, 5th and 6th as close ratio gears, not idea for a turbo powered car, i think a turbo works better when its got something to work against and a N/A just need to rev as fast and as high as possible hence the ST170 gearbox layout
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
A.t.p
Sep 29, 2015 05:04 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
