Removing ABS from a Mk3 Mondeo
Old Mar 4, 2007 | 11:16 AM
bluescortcossie's Avatar
bluescortcossie
try looking / asking on here
http://www.fordmondeo.org/forum
Old Mar 4, 2007 | 11:23 AM
OldDan's Avatar
OldDan
How come you want it removing? Is it quite restrictive?
Old Mar 4, 2007 | 12:15 PM
dojj's Avatar
dojj
Resident Wrestling Legend
ask one of the peeps who run a rolling road
i think they have to remove the fuse to get it to work on the rollers or soemthing
worth a shot
Old Mar 4, 2007 | 12:27 PM
RichieST's Avatar
RichieST
yes the ABS on my mk3 mondeo is rubbish, it seems to cut in a long way before the wheel wants to lock. And then when it was activated, the car just does not stop!!
I wish i could get rid of it too
Old Mar 4, 2007 | 01:14 PM
OldDan's Avatar
OldDan
It should be a fuse, I know when ZS's are run on a rolling road they need a fuse to remove the TC/ABS
Old Mar 4, 2007 | 01:22 PM
OldDan's Avatar
OldDan
Probably not, try them all until the TC/ABS lights come on.
Old Mar 4, 2007 | 02:06 PM
James's Avatar
James
You'll probably find it'll be a fuse in the fusebox under the bonnet and it'll probably have a little protective cover over it aswell.
Only thing to note is on the 04 focus when you pull the abs fuse the power steering goes tits up as does the speedo as both units get feeds from the abs ecu. Not sure if the mondeo is the same though?
Old Mar 4, 2007 | 02:45 PM
CJBear's Avatar
CJBear
u got hand book for your car, tells you what fuses for what; think there 2 fuses in aux box goto remove to disable it.
Old Mar 4, 2007 | 04:29 PM
CJBear's Avatar
CJBear
u wana leave the abs module pluged in but take the 2 associated fuses out the aux box in the engine bay, back of owners handbook is a list of fuses mate it tells you what ones to take out i think there like 15w or smaller fuses if my memory serves me right. Taking out the abs module itself aka the big fuse with the abs logo can give you probs when you put it back in the dash lights up like a lighthouse and wont go out if u unlucky.
155lee
Sep 6, 2016 11:10 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
hopper350
Sep 4, 2015 12:53 AM
Bighandsuk
Sep 2, 2015 05:23 PM
