Who has fitted a new 5bar manifold pressure and temp sensor
Has anyone fitted one of these yet and got rid of the map amd mat sensors ?
What ecu have you been running ?
Also philis do you have the techincal document for this ?
...dingy its the same spec sheet as per the older version...the temp part i cant get info on
..the new 5bar fits 2 different lorries hence you need the correct lead for application...the old map used to only fit one....and didnt have the temp part.
Phil have seen the lead and one end connects to the same pin on the other so its not needed LOL....
I just need to know the pin out of the actual device.
Do you not have access to technical documentation on the products you sell ?
Daz / Doug, are you using them as temp and pressure sensors.
...its the vehicle manufacturer that would be able to give you specifics,as far as you and me are concerned its a 5bar map sensor as per the original..forget about the temp bit.
I only have the documentation for the original as thats all bosch will give me!
COSWORLD
Aug 14, 2015 07:40 AM
track.focus'd
Aug 12, 2015 05:53 PM
