APT they are the best!!!
Went to have my abs removed they found out my master cylinder was shot manage to source a 2nd hand replacement all sorted they spent an awful lot of time fixing my car and only charged £150!!! they even threw in a free tune up.
Cheers lads for all ya help friday especially with the locking keys in car incident
oh and i did get to pick the Mrs up from luton airport on time only just though
I will defo be back for more work in the future
IMO, you need to completely replace the knuckle (the bit that the caliper bolts to and that the lower arm ball joint goes into) as it appears to be worn. A good second hand one will do there.
Its not a bad idea to have brand new Ford Track Control Arms while you are at it and then a decent wheel alignment. The arms are around £45 each from Ford and come with new Pinch bolts/nuts and Bushes.
Better still is to Poly Bush the front end too. But it depends on how far you want to go.
Ive got a full set of poly bushes at home so they could be fitted, i'll have a look and see if i can get a good 2nd hand knuckle!!!
What would the fitting charge be on the above items(knuckle, track control arms and front end poly bushes)
Christian can you tell me the part no for the master cylinder rebuild kit for my series2 its a 25mm bore one
The local ford garage says its been discontinued
Also can you give me a price for fitting polybushes to the front end i will supply them
Christian and Beccy
386
Feb 26, 2012 10:49 PM
Christian and Beccy
May 6, 2005 01:45 PM
Christian and Beccy
Trader Parts for Sale.
Feb 24, 2005 02:27 PM
