out of scan range
Old Sep 10, 2004 | 03:12 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
Default out of scan range
black screen with blue box sayin as title shows sometime on pc and have to reset,any ideas?>
Old Sep 10, 2004 | 03:25 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Usually means that your graphics card is outputting a resolution the monitor can't handle, too high a refresh rate if the res is ok, or maybe a dodgy connection in your cable that means the monitor is missing something (that would be likely if you have not changed anything recently).
Try wiggling the cable at both ends to see if you have a bad contact.
rsguy
44
Sep 29, 2015 03:29 PM
