Rear seat belt jammed
Old Feb 22, 2007 | 07:20 PM
j15ess's Avatar
j15ess
Default Rear seat belt jammed
Hello,
The middle, rear seat belt in my Fiesta Zetec is jamed, and it is due for it's MOT.
I have taken the plate off, on the back of the seat to access the mechanism, but I can't see what I can do with it?
Help! Any ideas?
Thank you!
Old Feb 22, 2007 | 09:52 PM
NUTS RuS's Avatar
NUTS RuS
Is it the middle lap belt ?
Some of those are non retractable
Welcome to Pf
Old Feb 22, 2007 | 09:58 PM
j15ess's Avatar
j15ess
Thank you for the welcome.
It is indeed the middle belt, however it is a full inertia seat belt. With a hatch for access on the rear of the seat.
Old Feb 22, 2007 | 10:06 PM
NUTS RuS's Avatar
NUTS RuS
Is it jammed open or closed (in or out) ?
Old Feb 22, 2007 | 10:12 PM
j15ess's Avatar
j15ess
It is closed. I don't think I have actually ever used it! I didn't even realise there was anything wrong until I pulled on it.
The inertia function has kicked in and the seat belt reel won't spin.
Old Feb 22, 2007 | 10:32 PM
NUTS RuS's Avatar
NUTS RuS
I know its daft and you possibly have tried it but - are you pulling from the right direction ? Sit in the seat and try to use it normally.
Push the belt back in about 1 inch to release the inertia and gently extract it by pulling slowly in the right direction.
Old Feb 23, 2007 | 09:00 AM
j15ess's Avatar
j15ess
Nope, tired that. It's not budging.
In fact, it is now not moving at all. Before it had a couple of inches of slack on it. Now it isn't going anywhere.
Old Mar 1, 2007 | 11:36 AM
DANROM's Avatar
DANROM
I had the same problem with a seat belt on a sierra.
I had to disassemble the housing and refit a little spring.
The spring comes out of its place and don´t make its job.
this spring is the one in charge of returning back a little hook, as that hook is the one in charge of retaining the belt, so the spring makes the hook loosen the belt.
So if that spring it´s out of its place the hook is retaining the belt all the time.
When you open up the seat belt housing. you will have to brake a little bracket. But don´t worry, you will be able to close again the housing without that bracket.
And here it is, the seat belt runs again.
This happened to me with all the seat belts. I unbolt them to rebuild my car and one year later when i went to fit them again, all of them where looked.
Now they all work fine.
Hope this will help you
Kam B
Sep 24, 2015 10:40 AM
jessie_rs
Sep 8, 2015 04:06 PM
cambo205
Ford Fiesta
Sep 6, 2015 07:45 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
