Central Locking Motors for Series 2's
Old Feb 22, 2007 | 12:36 PM
neilm's Avatar
neilm
Default Central Locking Motors for Series 2's
Are they the same as any other MkIV Escort ?
Are they still available from Ford ?
Are they expensive ?
Old Feb 22, 2007 | 01:12 PM
RS Bowk's Avatar
RS Bowk
Yes they are the same as any other mk4 escort
They are the same as a lot of fords also
Dont know if available from ford but u can get em at the scrap yard for about fiver
HTH
Old Feb 22, 2007 | 01:45 PM
Hardeep_Singh's Avatar
Hardeep_Singh
common problem specially in the winter
Old Feb 22, 2007 | 02:02 PM
SafeChav's Avatar
SafeChav
They all serve the same purpose but for some reason the very early motors in escorts & orions, and all fiestas it would seem, are nice and quiet. The later escort/orion motors sound shit!
I doubt you need motors mate, the latches go stiff in the winter, and a squirt of oil on the jopints usually sorts it out
Old Feb 22, 2007 | 02:51 PM
neilm's Avatar
neilm
I wasnt moaning about the sound, just the missus can only lock her Turbo on the Passenger side which is a pain in the dong.. and because its a pain for her its now a pain for me so I need to sort it.
Ironically, it locks and unlocks on the passenger side lovely lovely with the key, but when you try and lock it with the Alarm plip or the key on the drivers side it just locks and then immediately unlocks again.
So I am reliably informed its a problem on the passenger side.
Old Feb 22, 2007 | 03:13 PM
SafeChav's Avatar
SafeChav
Yea i know you werent complainin about the sound, but if your guna replace them there is 2 variants and the earlier ones are much quieter
Its worth checking the latches are screwed up tight to the doors, they have a habit of coming loose and causing similar problems aswell!
But if its not that a drop of oil on all the joints wouldnt go a miss before you start forking out
Old Feb 22, 2007 | 04:24 PM
neilm's Avatar
neilm
Cheers Guys..
I'll see if she's got any Anne Summers Lube to splash about..
Old Feb 22, 2007 | 05:39 PM
SafeChav's Avatar
SafeChav
Sounds expensive
Old Feb 22, 2007 | 08:57 PM
neilm's Avatar
neilm
Sounds expensive
Yeah... but smells nicer than WD40
Old Feb 23, 2007 | 11:46 AM
SafeChav's Avatar
SafeChav
I wouldnt know lol, you tart
AJC
Oct 8, 2015 11:09 AM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
rsguy
44
Sep 29, 2015 03:29 PM
