Cossie Alternator question???
Are the 2wd and 4wd 90amp alternators the same apart from the pulley?? i.e. the mounting points in the same place??
And can you still get a new alternator belt tensioner from somewhere??
I actually need a new tensioner too as I think the bearing is fooked in it!!! makes a right racket, till I squirt a bit of wd40 on it, then it stops for a bit.
put spray grese on it not wd as that takes away the oil/grease
jonfoc
16
Sep 11, 2018 05:35 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
