WHAT POLY BUSHES ARE BEST????
Old Feb 20, 2007 | 08:32 PM
jamie rst's Avatar
jamie rst
Default WHAT POLY BUSHES ARE BEST????
Hi pepole i am i the middle of restoring my escort rs turbo and i am after a full set of poly bushes and i know there are a few different makes on the market and i am sure i have read on here before that one set of poly bushes are not that good and i would just like to know what ones are the best to buy
thanks for any help on this pepole
Old Feb 20, 2007 | 08:51 PM
Alex_86's Avatar
Alex_86
Hm, its a few on the market.. and as always.. some will say that and some will say that.
deflex i do belive is the cheepest ones.. but not the best.. they also just come in to paper bags. (mine did=()
then u have powerflex, they are better and come in small boxes.
u also got superflex and some at rallydesigne.com that is better then that again. afther what i have heard
I use powerflex, but thou some deflex that powerflex could not get me when i order. and order the deflex to my cabby first befor i did get my s2
Old Feb 21, 2007 | 06:40 AM
POLY is POLY, no matter who it comes from it is the same liquid that makes them, they use different chemicals such as dyes, hardeners, elasticisers etc.
You can even mkae your own if you want to go to the bother of making moulds, which can be made from pretty much anything as it does not readily stick to moulds.
Colour has no bearing on hardness or SHORE rating, it is only the COLOUR OF THE DYE USED, it's natural colour is a cloudy white colour, same shade as glue sticks you can get for glue guns.
I use deflex as these are not a rip off unlike some.
There is a potentila for failure in any make of bush, usually due to trapped air in moulds.
There is no magic science to these bushes, a kid could do them, the POLY arrives in drums, you mix it with what you want, you pour into moulds, you let it set, take apart mould/pull out job done.
A lot make hype about injection moulding, this is purely because it is done on a large scale and adds nothing to strength of bush, just another AUTOMATED PROCESS as it is quicker cheaper to do.
At the end of the day if people gie you a lifetime warranty there cannot be much wrong with them.
DEFLEX for example made their name in OFF ROAD 4X4 stuff including events such as PARIS DAKAR, as well as all the top known ones, so are not going to be bothered by the stresses a car are going to throw at them.
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
