PC fans
Old Feb 19, 2007 | 07:55 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Default PC fans
Think I need a new one as they're making a bit of a racket and my PC keeps shutting itself down. I think it's getting a bit too warm.
How much is a fan (or are they a pair ?) Easy for an idiot to fit himself ?
Old Feb 19, 2007 | 08:01 PM
arch's Avatar
arch
Fans are a couple of quid, very very easy to fit, just bear in mind they are designed to blow one way, they normally have a little arrow on em.
Are you sure it's not your power supply on the way out?
Old Feb 19, 2007 | 08:07 PM
Mr S1's Avatar
Mr S1
No idea mate, but it only seems to do it when the house is quite warm. Heatings off tonight and no problem (so far anyways) at all, so thought I'd try the fans first ? Can you buy uprated / bigger ones ?
Old Feb 19, 2007 | 08:13 PM
S1's Avatar
S1
Take a look at the processor heat sink and check it isnt clogged up. It doesn't take much dust for it to overheat the CPU.
Old Feb 19, 2007 | 08:14 PM
Mr S1's Avatar
Mr S1
OK, but plain English here mate what does it look like and where does it sit ?
Old Feb 19, 2007 | 08:15 PM
Thrush's Avatar
Thrush
Irritating c........
Exactly as above. My friend at works PC was constantly turning itself off when it got "warm" but turned out to be the finned heatsink on the CPU was stuffed full off dust, and a quick blow out sorted it right out - worked fine after that
Old Feb 19, 2007 | 08:16 PM
Mr S1's Avatar
Mr S1
OK, sounds like this could be first point of call.............I can take the side off and blow the dust away from everything - whats this CPU heat sink look like, and as above - where is it ?
Old Feb 19, 2007 | 08:17 PM
Thrush's Avatar
Thrush
Open up the PC and look for something like this;
Make sure it doesn't have lots of dust in it
Best thing to do is give the inside a good blow out - don't hoover it tho FFS! Lots of little bits that can "dissapear" with the suction from a hoover A good blow out will work - either get them lungs working or get a small can of compressed air and blast the case (not too close mind)
Old Feb 19, 2007 | 08:19 PM
JamesH's Avatar
JamesH
Also check the fan on the back of your power supply (where your kettle lead plugs in) in actually spinning!
Mr S1's Avatar
Mr S1
You sir are a gentleman and a scholar cheers to you other lads as well. Will give that a go, maybe tomorrow night. Compressed air, here we come........take it you can buy that in PC World ?
Old Feb 19, 2007 | 08:21 PM
Thrush's Avatar
Thrush
NOt a great pic (the one above), but just using Google pics...
It might well have a fan on it (in fact I'll gaurantee it'll have a fan on it) so it'll probably look more like this;
Old Feb 19, 2007 | 08:23 PM
Thrush's Avatar
Thrush
No probs And you probably can buy it in PC World, but to be honest, I just take mine outside (so as not to get dust everywhere) and open the case and get the lungs working! A Good few puffs and you should see dust in the air If you have a hoover with "blow" function, then this will work aswell - just don't touch anything with the end of the hoover
Old Feb 19, 2007 | 08:25 PM
Mr S1's Avatar
Mr S1
Oh I'll do that then. I can go down my shed and do it down there on the workbench.
Job for tomorrow night cheers Thrush, much appreciated
Old Feb 19, 2007 | 08:27 PM
Thrush's Avatar
Thrush
NO probs
*disclaimer - if for any reason your PC does not work after taking it down the shed, then plugging it back in again after - I hold no responsibility!!!!*
Old Feb 19, 2007 | 08:29 PM
Mr S1's Avatar
Mr S1
NO probs
Even I can take the side off it, blow the dust away and put the side back on, surely...............
Old Feb 19, 2007 | 08:31 PM
Da Booga's Avatar
Da Booga
Famous last words
Old Feb 19, 2007 | 08:33 PM
Mr S1's Avatar
Mr S1
Famous last words
SSShhhhhhhhhhhhhhhhhhhhhh......................... ................
Old Feb 20, 2007 | 06:23 PM
Mr S1's Avatar
Mr S1
Result - all's well so far......................
Old Feb 20, 2007 | 06:28 PM
Graham S1's Avatar
Graham S1
NO probs
and while the covers off, turn it on to make sure the processor fan is actually working.
Old Feb 20, 2007 | 06:32 PM
had the same problem with my comp last year
one can of air duster later hey presto
Old Feb 20, 2007 | 06:39 PM
Stu.H's Avatar
Stu.H
Yep, did one at work
I swear if Id have had some knitting needles I could have made a jumper out of the crap that came off the heatsink/fan
Old Feb 20, 2007 | 06:50 PM
Mr S1's Avatar
Mr S1
Yeah a fair bit of shite came out I have to say................where it came from though I don't know !! Did as Thrush said round the heat sink thingy and fan though. Used a paintbrush to clean the fans themselves.
Old Feb 20, 2007 | 07:15 PM
BM08's Avatar
BM08
yeah you can pick them up from ebuyer for as little as 99p or pc world for a few quid
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
simonmcf
Sep 22, 2015 08:40 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
