loom for efi conversion
i can get my hands on a engine loom from an 1.8 xr2i can i use this loom to convert my erst to efi managment or does it have to be a fiesta turbo ofab loom
you can use a xr2i loom, just need to reconfigure the pins on the ecu plug and disconnect pin 2 on the edis module (for OFAC anyway, you should check for OFAB), I just converted my friends RS 1800 over to cvh turbo running OFAC, I used a xr2i bay loom, modified the bay loom plug to match the RS 1800 loom and works very well. just remember that any loom can be converted to work with anything, its only single wires going to and from the right pin on the ecu to the signal pin of the sensors.
Hope that helps a bit
mk3ste
Oct 17, 2021 10:09 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
